Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 64
  1. #21
    Dec 2006
    612
    Once I had the tube flanges where I wanted them I welded them together.
    Sorry I got carried away on the project & by the time I remembered to take pictures I had the outlet tube firewall sheet metal done.
    This is the firewall before...
    and with the intercooler tubes part of the sheet metal in place.
  2. #22
    Dec 2006
    612
    The inlet side is just a simple pie plate deal that will be trimmed & welded into the firewall eventually.
    The outlet side was a little more complicated. I didn't want to run the plumbing off to the side (the way it's usually done). I wanted the carb hat facing straight back. Also, the engine is set back about 4" from the stock location. So, the 4" inlet tube has about 3/8" clearance between the windshield and about 1" clearance for the distributor. It's all pretty close but it fits. . The "through the firewall sheet metal'' for the inlet tube ended up looking sorta like shoving the flange through a hefty hefty trash bag.
    ...and here's what it looks like from "the office".
  3. #23
    Mar 2009
    Corona, CA
    213
    As always, you never cease to amaze. Still rockin on with that good work. But you dont need me to tell you that.
    Its a long long road...but I want to see that beast when its finally done!
    Precision is only as important as the project...if you're building a rocket ship...1/64" would matter. If you're building a sledgehammer...an 1/8" probably wont.
  4. #24
    Dec 2006
    612
    Thanks On Fire. yes, it's been a long haul and still a long way to go. Got too many things goin'*on & this project finds itself on the bottom of the list most of the time. forgot I took some shots of the process when I stamped the shallower inlet side.
    I cut the 3/4" MDF out on the CNC. I gave one side 1/8" clearance for the metal and the other side the circle press fit into the MDF.
    This made the die the right depth (I needed it to be stamped 1/2" deep for the right offset). It also made it easy to register the die halves.
    Once out of the press all I had to do was hammer the tucks and it's ready to trim to the firewall. The firewall that doesn't exist yet.
  5. #25
    Dec 2006
    612
    Got a little more done on the firewall this weekend between honey -do projects.
    I made a hammer form out of a 2x4 on the band saw to match the contour of the firewall and beat some metal into submission. Still needs a little hammering but it's close enough for a test fit.
    I decided to do recessed panels on the sides & I think I'll do raised panels on the front, but I've changed my mind so many times already, who knows.
    This part of the firewall will get welded to the body. The rest will get welded to the chassis and the 2 will be bolted or riveted together (blind seam) from the inside
    I think I spent more time in the lawn chair thinkin' about this than actually working on it. I kept changing the plans until I had a headache & finally decided to just do something. If it doesn't work I'll start over. I want to be able to take the body off, so that's why it's going to be a 2 pc. deal. Sort of the same reason I spent all that time on the billet aluminum hinges rather than just welding them to the chassis. Keeping the "A" pillars I'll still be able to use stock door weatherstripping and boxing in the firewall under the windshield I'll be able to keep the stock windshield wipers, got to keep it street legal right?
  6. #26
    Mar 2009
    Corona, CA
    213
    Definitely should. You'll HAVE to pick up groceries in it at least once.
    Looking good though, I'd say you're onto something. Good use of Cleco's too!
  7. #27
    Dec 2006
    612
    Thanks On Fire. Got a little more done on the firewall this weekend, Welded a few of the small pieces to some of the medium sized pieces.
  8. #28
    Dec 2006
    612
    Made another piece for the inlet side of the intercooler tonight.
  9. #29
    Dec 2006
    612
    And got a panel installed.
    I roughed up the back of the panel & the chassis tubes with 80 grit on the angle grinder, then glued it in with fusion body panel adhesive.
  10. #30
    Dec 2006
    612
    Added a couple more pieces to the puzzle this afternoon.
