Results 1 to 7 of 7
    4
    Default Welding an engine block, correct procedure?
    Hello,
    I need to weld a crack on a Farmall Cub engine block. If anyone is familiar, it is the casting that is typically cracked when the tractor is pulled by its front axle. Apparently, someone has attempted to repair it on the tractor in the past and this will need to be ground off to start over. It looks like they might have used a nickle rod. I am planning to remove the engine from the tractor for this repair.
    Question: What is the correct procedure to do this and can I use a MIG or should I go back with a rod and if so, AC or DC-/+? What about pre-heating to prevent additional cracking? I know I need to weld it slowly and not rush the job. Can anyone recommend a good rod that I might be able to find at my LWS?
    Thanks in advance.
    Vinnie in NC
    Dec 2005
    wisconsin
    836
    Quote Originally Posted by VinnieNC View Post
    Hello,
    Thanks in advance.
    Vinnie in NC
    Best practice involves stripping down to a bare block, preheat to about 1200 F , OA weld with cast iron filler and flux, and then post heat to about 1500 for an hour or so then let slowly cool.
    Notice I didnt say the easiest, but its the best.
    -Aaron
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Miller Spot Welder
    Motor-Guard stud welder
    ****inson ND
    557
    Talking
    Quote Originally Posted by makoman1860 View Post
    -Aaron
    Does this method require welding only an inch at a time and peening like SMAW requires?
    Dec 2005
    wisconsin
    836
    Quote Originally Posted by Anti-GMAW View Post
    Nope, it doesnt require crutches or band-aids.
    Miller Spot Welder
    Fraser Valley, BC
    593
    Default To weld or not to weld
    Although you can repair a cast iron block by welding, most repairs are made using plugs. Generally a series of holes is drilled along the crack, tapped and then plugs are screwed into the tapped holes. An internal bladder can be used inside the block in order to prevent leaking. This technique can also be used on cylinder heads. Of course, being welders, why would we want to take the easy way out. Good luck on your repair either way.
    Makita 5" grinder
    Makita 14" abrasive saw
    IR SS5L compressor
    and a wish list a mile long
    Default Welcome to LOCK-N-STITCH Inc. - Cast iron repair is our specialty
    We can fix it or you can fix it; either way, we can help
    http://www.locknstitch.com/
    LOCK-N-STITCH Inc. specializes in all aspects of the repair of cracked and damaged cast iron and other cast metals. LNS manufactures crack and thread repair products, provides training in crack repair techniques and maintains a full-service repair department that performs repairs all over the world and has the benefit of over thirty years of experience.
    Whether you want to metal stitch a damaged casting yourself, want our professionals to do the job, or need an on-site consultant to advise and train your personnel during the repair, we have the supplies, the skills, and the people to assist you. Quite simply: we can fix it or you can fix it.
    Please review our web site and see what we have to offer to you and your company. Our site is organized into eight main sections: Metal Stitching, Thread Repair Inserts, Stitching Products, Service, Training, Technical Support, Cast Iron Welding and Repair Examples. Visit the ones that interest you the most and let us know how we can be of help.
    We manufacture and sell products covered under US Patent No. 5,379,505; 5,417,532; 5,499,892; 5,562,371; 5,944,303; 6,071,051; 6,126,367; 6,212,750; 6,261,039; 6,382,893; 6,435,788; 6,439,817; 6,572,315; 6,725,518;
    Australian Patent No. 684525; Russian Patent No. 2137581. Many additional international patents have issued and are pending.
    Thank you for the visit. Please come again.
    Dec 2005
    wisconsin
    836
    Quote Originally Posted by Harvuskong View Post
    Yeah,
    Ive seen that repair.....in fact I have seen it fail quite often on warranty parts. I guess it has its place, but id put it below a weldment.
    Miller Spot Welder
