Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Clamps
  1. #21
    Mar 2009
    Corona, CA
    214
    I buy the 6CR Visegrip, the 11sp, and the really big mama jama, 24sp. Expensive but worth it for the throat depth. I usually use the swivel pad version because the other style tends to crush square tube (just a bit) when you have it set hard enough to hold everything in place. Takes more time to metal finish stuff out and get it ready for powdercoating/painting.
    Ive used their sheet metal pliers...and the welding pliers...but they arent worth the extra cost. I can buy 2 or 3 more 6R's or 8R's, and weld some steel plate to them for the same job. They dont look as pretty, but its a bunch cheaper.
    I dont clamp really heavy duty stuff though...usually the most I work with is .120 wall.
  2. #22
    Jan 2009
    15
    Bessey WSM welder's 90 degree clamps
