Results 11 to 20 of 22
Thread: Clamps
    Aug 2008
    Krefeld, Germany
    18
    They are very expensive. I didn't find a website with pricing. The big ones and the bar clamps cost several hundred $ each, the small ones will start in the high two-digit range. But every now and then a few used clamps in good condition can be found on ebay. That's how I started my collection, I've never bought one new.
    Steffen
    Krefeld, Germany
    May 2007
    Dallas, Texas
    323
    Anyone have any experience with Gross Stabil? They're German made.
    http://cgi.ebay.com/Gross-Stabil-Hea...d=p3286.c0.m14
    Millermatic Passport Plus
    Millermatic 350P with Python
    XMT 304 /w S-64 feeder and 12VS
    Dynasty 300 DX
    Thermal Arc 400 MST
    Premier Power Welder for my trail junk.
    Aug 2008
    Krefeld, Germany
    18
    Gross-Stabil is part of the Bessey group.
    So yes, they're ok.
    Steffen
    Krefeld, Germany
    Jun 2009
    Tallahassee, FL
    67
    I saw these aluminum corner jigs and I know their not clamps but I four of want them!
    Millermatic140; Spectrum625; Bobcat250; Lincoln AC225; Bosch grinder
    May 2007
    Dallas, Texas
    323
    Quote Originally Posted by chevyman_de View Post
    So yes, they're ok.
    Steffen,
    Thanks for the reply. Would you say the Gross-Stabil are as good as Bessey?
    Thanks,
    Charles
    Dynasty 300 DX
    Thermal Arc 400 MST
    WY...armpit of U.S.A.
    636
    Not in line with Bessey's Heavy Duty models, at least not for the clamp you linked to. That Gross-Stabil clamp has a nominal clamping pressure of 2800 while an 18"...sorry, no 20"...Bessey Heavy Duty model is rated at 4880 lbs. Gross-Stabil may indeed have a heavier duty model available that would go head to head with Bessey, but I would imagine they would also be priced similarly.
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
    Orlando / Daytona, FL
    142
    I've got a couple sets of these in various lengths
    http://www.amazon.com/Vise-Grip-VIS1...342298&sr=8-13
    keep in mind its overall length and not throat depth
    works good for setting stuff up on my table
    i have the ones with little pivoting feet, not the rounded points like the picture above
    Justin Starkey
    Syncrowave 250 TIGRunner
    Miller 210 MIG
    Spectrum 375 Plasma
    Ford and GM Dyno-tuning on the Moblie Dynojet trailer I built.
    VMP Tuning.com
    Aug 2008
    Krefeld, Germany
    18
    Gross-Stabil is now 100% Bessey, same product, same label. When you go to http://www.gross-stabil-tool.de, a Bessey website opens. They do no longer make any clamps with the Gross-Stabil logo.
    Bessey has a very large range of clamps, which makes comparing them to other makes a little bit difficult, because there is no "the Bessey clamp".
    Their catalog has about 95 pages of clamps.
    The biggest advantage of the carver clamps (in my opinion) is the fact that it takes almost no effort to tighten them down. You can reach their clamping force with one hand, no need for additional wrenches or extensions to turn the spindle.
    The spindle is covered, well protected against weld spatter. And, just in case, you can get spare parts for them...
    Steffen
    Krefeld, Germany
    Jul 2006
    1,508
    The Bessey and Wilton type clamps are great for what they do. But they don’t have the umf that these do.
    When splicing beams and the flanges don’t match you’ll destroy a Bessey trying to force the flanges together. We have gang boxes full of these!
    Aug 2004
    Milan Michigan
    1,418
    CevyMan, I have one of those clamps which which is a strong clamp but clumsey to use. I saw the price of my 24"er and about fell over.
    I have found Bessy clamps to be the most versitil
    Sanora showed us what are called beam clamps which are slow to use but by far the strongest.
    The clamps I use the most are the bessy and 11R by vise grip.
    I currently do not have any beam clamps.
