the pads welded to the tank i used 045 flux core, the eye plates i used 035 solid wire. the pads had two passes, the first was in a bevel. i was worried about the heat in the tank's wall, and compromising that. the fillet on the 3/4 plate is about 5/16. with the disperssment of the weight, each eye is carrying about 4000 pounds. those would still be a concern?
Results 41 to 50 of 54
Thread: MIG or stick on this one?
09-08-2009, 05:30 PM #41
- Jun 2009
- Shelton CT
- 179
F450 crewcab flatbed
Miller Bobcat 250
Miller 8VS suitcase
Millermatic 251
Millermatic 180
Miller Spectrum 375
Miller Econotig & 150 STH
Enough snap-on tools to prevent my future kids from going to college
09-08-2009, 05:55 PM #42
I personally don’t have too much concern with the welds of the doubler plate to the tank, just on sure weld volume alone. My concern is the padeye to doubler plate! I forgot, the riggers plan on laying this tank down correct? If so the forces into these padeyes will change / rotate. If it were just a simple vertical pick, I would still have concerns, but not as much. I think you’re living dangerously here!
09-08-2009, 05:58 PM #43
- Dec 2007
- southern California
- 1,783
I'm not an engineer and can't tell you how many lbs of force in what direction your welded joint will hold. If 3/4" plate was the plate size decided on as sufficiently strong for the application, then your welds need to match the plate size, which they fall short of by alot.
Now if a 1/4" plate was decided to be sufficiently strong for the application but you used 3/4" because that's what you happened to have around, then a 5/16" fillet size would be strong enough, if applied hot enough to properly penetrate and fuse. The ones pictured don't appear hot enough to me.
I like that you beveled the plate to tank joint and put in 2 passes. I wonder how well the bevel filled in, if it penetrated through to the root and how good the fusion was. I wouldn't worry so much about compromising the tank wall by putting in more and hotter passes. There's a huge area there to soak up the heat and you're not going to be blowing through it.
I would go back and put in more passes till they're full.
I forget what was the number you decided on. How many of these eyes are being used around the tank?Millermatic350P/Python, MillermaticReach/Q300
Millermatic175
MillermaticPassport/Q300
HTP MIG200
PowCon 300SM, MK Cobramatic
DialarcHF, Radiator-1
Hypertherm PowerMax 380
Purox oxy/ace
Jackson EQC
-F350 CrewCab 4x4
-LoadNGo utility bed
-Bobcat 250NT
-PassportPlus/Q300
-XMT304/Optima/Spoolmatic15A
-Suitcase8RC/Q400
-Suitcase12RC/Q300
-Smith oxy/propane
-Jackson EQC
09-08-2009, 06:00 PM #44
- Jun 2009
- Shelton CT
- 179
8 anchor points.
Miller Bobcat 250
Miller 8VS suitcase
Millermatic 251
Millermatic 180
Miller Spectrum 375
09-08-2009, 06:08 PM #45
09-08-2009, 06:17 PM #46
- Dec 2007
- 1,783
8 is better than the 4 or 5 that I thought it would be.
Still, if it was my @ss on the line with this project, seriously, I would definately go back in there and fill those suckers up, both the t-joint and the plate to tank seam, and crank it up too!
Please, don't think I'm trying to ridicule you. Only trying to help.
On your shop work, your Millermatic 251 is capable of spray transfer with .035 wire. Pick up a bottle of 98/2 argon/oxygen so you can play with spray. If you have future heavy plate jobs and want to use solid wire and gas, spray it. The welds will go in alot hotter, wetter, deeper penetrating and better fusing, cleaner too. Must be used flat/horizontal only, no out of position. Anything over 1/4" should be sprayed rather than short circuited, with mig solid wire. Play around with it, you'll love it!
Millermatic175
HTP MIG200
Purox oxy/ace
Jackson EQC
-F350 CrewCab 4x4
-Bobcat 250NT
-PassportPlus/Q300
-Suitcase8RC/Q400
-Suitcase12RC/Q300
-Smith oxy/propane
-Jackson EQC
09-08-2009, 06:17 PM #47
- Jun 2009
- Shelton CT
- 179
from what i can decipher from the scribbled notes and diagrams on the crane cut sheets that came along with the cut sheets on shackle size, they're using cable lanyards from the shackle to the crane hook.
if this makes any sense.
Miller Bobcat 250
Miller 8VS suitcase
Millermatic 251
Millermatic 180
Miller Spectrum 375
09-08-2009, 06:37 PM #48
Actual rigging is not on the lift plane.
Rough drawing of a flying W, you can use shackles in the bite of the 2-chokers, but I would not lay an object down like this, the shackles will destroy the chokers. This type of rigging is great for some lifts. I would use only two chokers to four padeyes, and use snatch blocks in the bite of the two chokers, that way you can lay it down no problem.
09-08-2009, 07:16 PM #49
Sorry guys I drew that first drawing wrong
. It will be clearer just showing one side.
09-08-2009, 09:36 PM #50
- Apr 2009
- KANSAS
- 511
fillet size
Hey, while we are on the subject, kinda. I thought fillet welds were supose to be 1.25 times the material thickness so two peices of 1/4'' plate would require a 5/16'' fillet. Or is it 1-1/2 times the thickness.
Just curious. I can't remember.'08 F-350
Vantage 400
SA-250
SA-200
Invertec V350Pro
Invertec V205T-AC/DC
Miller 12VS suitcase
Miller spectrum 2050
Pipe beveler's
Track torch
