Results 31 to 40 of 54
Thread: MIG or stick on this one?
09-07-2009, 07:49 PM #31
- Jul 2008
- East Tennessee
- 609
Bernard 3500ss water-cooler
Rockwell vertical mill
Beverly Shear B-3
Beverly Shear JR
Home-made English wheel
Milwaukee Porta-band
" Sawz-all
Tennsmith 36" stomp shear
Fixer upper 1982 Lincoln sa200
09-07-2009, 07:52 PM #32
- Jun 2009
- Shelton CT
- 179
they wouldn't allow any work there today, so they pushed the crane off until wednsday. i'll be up there 5am tomorrow.
heres a pic from saturday
F450 crewcab flatbed
Miller Bobcat 250
Miller 8VS suitcase
Millermatic 251
Millermatic 180
Miller Spectrum 375
Miller Econotig & 150 STH
Enough snap-on tools to prevent my future kids from going to college
09-07-2009, 09:34 PM #33
- Apr 2009
- KANSAS
- 511
Just for fun. How did you weld them?
'08 F-350
Vantage 400
SA-250
SA-200
Invertec V350Pro
Invertec V205T-AC/DC
Miller 12VS suitcase
Miller spectrum 2050
Pipe beveler's
Track torch
09-08-2009, 03:23 AM #34
- Jun 2009
- Shelton CT
- 179
mig. ended up to be 44 linear inches of 3/8" fillet around each pad.
Miller Bobcat 250
Miller 8VS suitcase
Millermatic 251
Millermatic 180
Miller Spectrum 375
09-08-2009, 04:51 AM #35
If you get time and think about it, I for one would be very interested in seeing a picture of the padeyes. I have done this type of work my entire career. I’ve come to the conclusion there is more than one way to design a padeye. I’m confident I’ve seen it all, but you just never know. I’ve seen padeyes that made me want to leave the county before the pick was made, and I’ve seen engineered padeyes that just floored me on how stout they were designed. Interesting work! (To me anyway)
09-08-2009, 06:09 AM #36
- Sep 2005
- 4,247
One of the biggest failures I was ever around was an engineered deal, I asked before we did it, had a gut feeling but they the ones with the degree. Crap happens fast though.
09-08-2009, 03:23 PM #37
- Jun 2009
- Shelton CT
- 179
heres the uphill (the 3/4" plate was welded at the shop)
and the overhead
Miller Bobcat 250
Miller 8VS suitcase
Millermatic 251
Millermatic 180
Miller Spectrum 375
09-08-2009, 03:45 PM #38
Thanks for posting the pictures!
I’m a little surprised that you didn’t go with gussets. I think it was you, or maybe someone else posted about using a T shaped padeye, I was all for that! I’ve welded lots of engineered padeyes made from T shape. Just cut two slots in the top for the bail of the shackle to insert into. Cut a hole in the web for the shackle pin.
I know you’re a little defensive with some of the comments you have received. But I’d add more weld, and a lot hotter! Then again I’m not a big fan of Mig, even tho I’ve passed numerous structural DT tests with Mig, just not a big fan!
09-08-2009, 03:57 PM #39
Maybe I should clarify about my statement of making more weld: Not so much on the doubler plate, but the padeye it’s self. I would also weld all the way around!
09-08-2009, 05:13 PM #40
- Dec 2007
- southern California
- 1,783
I've been reading this as it's unfolded. Not being an engineer or rigger, I didn't have anything to add to the discussion about how many eyes or where, etc.
I don't like to rain on anyone's parade and don't take this the wrong way but, I gotta speak up...
Hate to be the bearer of bad news, but your fillets joining the two 3/4" plates are WAY UNDERSIZED for that size t-joint. Fillet weld leg lengths should be 3/4" minimum on each leg for that plate size, if that is 3/4" plate. Those look to be about 1/4" to 3/8" fillet legs. You need to go back and put at least 3 more passes in on each fillet to fill them up to proper size, probly more like 5 more passes. I would weld them around the ends too.
The vertical tank to plate fillets look good, but are also undersized. They look to be maybe 1/4" leg length at most, hard to tell from the pic. I would go back and put 2 more passes over those. Also, they don't look hot enough to me have good penetration and fusion with that thick plate. Together with being undersized, you have an insufficient strength joint there, in my opinion.
The overhead tank to plate fillets don't look like they grabbed very much of the tank. Most of the bead is on the plate, though they do look a little more wet in to the plate than the verticals do. They're too small too. I would go back and put 2 more passes in on those too. Going by the rest of it, I would put in 2 more passes on the horzontal joints on top too.
Your beads look nice overall, but overall I don't think you have nearly enough weld in there holding all that together. Please don't be offended or think I'm trying to be over critical. I just don't think those are stuck on there good enough considering what they'll be used for.
What wire size and type did you use? What volt/speed settings?
On plate that size with a mig, you should be using spray transfer. The beads and spatter around them look like short circuit transfer to me. Not hot enough for that size material to give good penetration and fusion.
Crank 'er up and fill 'er up, bro!
Standard fillet weld sizing- Each leg of the fillet in a t-joint should be at minimum equal to the thickness of the thinnest plate in the joint.Last edited by Desertrider33; 09-08-2009 at 05:29 PM.
Millermatic175
MillermaticPassport/Q300
HTP MIG200
PowCon 300SM, MK Cobramatic
DialarcHF, Radiator-1
Hypertherm PowerMax 380
Purox oxy/ace
Jackson EQC
-F350 CrewCab 4x4
-LoadNGo utility bed
-Bobcat 250NT
-PassportPlus/Q300
-XMT304/Optima/Spoolmatic15A
-Suitcase8RC/Q400
-Suitcase12RC/Q300
-Smith oxy/propane
-Jackson EQC
