Results 1 to 7 of 7
    Mar 2009
    Akron, Ohio
    52
    Default Fabricating a merge collector
    I am in the process of building a turbo manifold, and am in need to make a 4-1 merge collector. I am using all sch10 304ss 1.5" tubing/fittings. So pretty much all I have been using is a 14" cut off saw for cutting my materials. So, any ideas on how to fabricate or even begin to design a nice collector? I know I can purchase one online for about 100 bucks, but I like learning/trying new things to do things on my own
    Lake of the Ozarks MO
    3,447
    Obviously you are going to need some other method of cutting small parts.
    Fit-up on a part such as this is everything IMO.
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
    Mar 2009
    Akron, Ohio
    52
    What would you recommend using?
    I've seen people use a verticle bandsaw to make the cuts for the manifold pipes. Gave a nice cut and it's easy to position the pipes so you get the cut you want.
    Baldwin, NY
    275
    I havent made any merge collectors, but I have made a couple high velocity merged y pipes. I use a vertical metal bandsaw...
    PS. the $100 merge collectors are junk... a good one is ~$500 easy....
    Voigt Precision Welding, Inc.
    Miller Dynasty 200 DX, Miller Syncrowave 250, MillerMatic 252, Hypertherm Powermax 45, Auto Arc Trailpower 8000,272+187 lb Peter Wright anvil, 120 lb Fisher-norris, and more! Buffalo drill press, Grizzly Horiz. Bandsaw, Edwards shear, Barth Shear, bantam mechanical ironworker, Hopkins fly press, Doall Bandsaw, brown and sharpe surface grinder.
    2007 Silverado 2500HD (tow vehicle)
    2000 Camaro SS (Race car)
    Jul 2007
    241
    Any one have any specific models of a metal cutting vertical band saw that they have had good luck with? How about any smaller units that dont take up too much space?Thanks Mike
    Sep 2009
    3
