Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. #21
    Sep 2009
    Waterloo, IL
    15
    Quote Originally Posted by blown99gt View Post
    crazy.. you gota have a big pair to do that stuff! ill stick to 4 wheels
    All in what you get used to I guess. It is not a beginner ski boat... that is for sure.
    Wags
  2. #22
    Sep 2009
    Waterloo, IL
    15
    Quote Originally Posted by wagspe208 View Post
    A couple hundred passes later... looks great!
    Wags
    Oh, yes.. that is exactly how is is supposed to ride. The front sponsons are there for the ride after the launch. Bottom 1/2 of the prop in the water.
    BTW... if you look at the back of the boat you see a black square behind the engine. That is the parachute. Look directly in line below that and you see a black piece with a shaft going forward. That is the strut.
    SO, you can see it carries the boat weight plus a ton of side load. (from bottom half of prop)
    Wags
