It is not ugly white anymore. I will see if I have any good pics.
Wags
I have to get a spectacular shot scanned in the computer. I will give it a whirl in the next few days.
Results 11 to 20 of 22
Thread: Welding 1/2" 4140 bar
09-07-2009, 09:56 PM #11
- Sep 2009
- Waterloo, IL
- 15
09-07-2009, 10:10 PM #12
Member
- Apr 2007
- Colorado
- 35
Omg
Holy chit mahn!! That's an engine! Couldn't you find a little bigger one to put in there? I like you logic - good luck in your solution.
09-08-2009, 12:57 PM #13
- Sep 2005
- 4,246
Actually 2 ft drops of beams are common in fab shops, scrap bins are full of them as there isn't much call for short drops. I personally wouldn't make it from an exotic alloy if mild would do.
07-04-2010, 11:45 PM #14
- Sep 2009
- Waterloo, IL
- 15
Well, just a final update.
I preheated the metal to 600F. Welded it in 2" sections alternating ends, etc to kep it from pulling all to ****, let it cool slowly and bolted her in. I could not have asked for it to work any better. Alignment was awesome. Weld seems to be excellent. It has about 50+ passes on it at 150 mph or so. (8) 6.0 runs at 1000' also. This takes 1200+ Hp ish to do. I have always and still do look at it every pass.
Preheat is my friend.
Thanks for the help.
Wags
BTW, I milled a slot in the top plate and pressed the vertical part in to the slot. I welded on the top then and around the bottom. (so this is about 30+ inches of weld total) The tube (that the propshaft goes through) I milled a slot for alignment and it had about .001 press to the vertical piece.
PS we won the last 4 out of 5 races after that. 1 for 10g.!!
07-04-2010, 11:58 PM #15
still wanna see pics of that beast in actions, please? i am glad that it worked out for ya. i didnt see this post until now. shoot me a pm next time you need a 2 or 3 foot drop of some heavy beam...... heck, i even have a 6 ft drop of 38 inch beam 390 pound per foot
07-26-2010, 11:50 PM #16
- Jan 2009
- Whitehorse, Yukon
- 280
Looks like you already got 'er done, cudo's!! For future reference tho:
Preheat 5-600 degrees, if possible weld with a nickel/chromoly rod (such as Arctec's Unicrom series) and cool slowly. If you can't find that rod, ER80S-D2 is a real decent option for MIG wire. In the mean time, have fun!!
WHBig Blue 400D
Trailblazer 302
Miller S-32 suitcase
12VS suitcase
Lincoln LN-7 (BIG suitcase)
Victor torches
Lincoln 350MP with 35' push-pull gun
Lincoln PrecisionTIG 375
Spectrum 1000 plasma cutter
08-11-2010, 03:53 AM #17
- Aug 2010
- 1
4140
you can use duplex(2209) or super duplex(2507) with about 400f pre heat. It is very good for any sort of dissimilar welding
07-21-2011, 09:08 PM #18
- Sep 2009
- Waterloo, IL
- 15
A couple hundred passes later... looks great!
Wags
Oh, yes.. that is exactly how is is supposed to ride. The front sponsons are there for the ride after the launch. Bottom 1/2 of the prop in the water.Last edited by wagspe208; 07-21-2011 at 09:11 PM.
07-21-2011, 09:21 PM #19
- Sep 2009
- Waterloo, IL
- 15
Put some graphics on over the winter. Had to break up the red a little.
08-07-2011, 09:08 PM #20
Member
- Oct 2010
- 35
