Results 1 to 10 of 18
    Apr 2007
    NJ
    23
    Default Tube notching / fishmouths
    What's the best way to find angle of tube for notching ?
    Feb 2009
    Lodi, CA
    1,126
    It's been talked about here before, many times. Dig around in this link you'll probably find the answer you are looking for.
    Jun 2006
    Calgary, Alberta
    377
    I don't know if this will help, but there is a free program called 'tube miter' online, look it up, download it.... it will print templates for miter joints on all sizes of tube up to around 3.5". It will calculate all angles, and print temps for connecting different sized tubes together of different wall thickness.
    Jonny
    Dynasty 300DX
    Esab PCM 1000
    Nov 2008
    Kansas City Metro
    387
    Here is a link for pipe joints, enter the numbers and thickness and just hit submit. It opens a printable page with the template on it. I have never used it myself, just came across it and thought it was worth saving.
    http://www.harderwoods.com/pipetemplate.php
    Good Luck
    Stickmate LX 235 AC / 160 DC.
    Clarke 180 EN Just in case
    Spectrum 375 X-Treme.
    Milwaukee 14" Chop Saw.
    4 x 6 Horizontal Band Saw.
    Projects and Misc Albums
    http://picasaweb.google.com/keesfriend Feel Free to Have a Look ( Just keep in mind I am an amateur )
    Nov 2008
    Colorado Springs
    272
    Default Tubemiter program
    here is copy of the FREE tube miter program(runs in windows)
    I had "Zip it" to upload it.
    Everthing MM but it works pretty good
    Attached Files Attached Files
    Live Right Have Fun
    XMT350 CV/CC
    22A Feeder
    MM175
    TB302
    12vs Extreme
    Hypertherm PowerMax 1000
    20" x 40" CNC Mills (2)
    16" x 60" engine lathe
    65 Ton edwards iron worker
    3/16' x 24" power slip roll
    16' power feed mitering bandsaw
    and other fun toys
    Sep 2009
    southeast mich.
    28
    those programs are worthless unless you are notching with a saw or a grinder. if you already know the intersection angle, you know the notch angle too. i just fit up a cage yesterday and eyeballed every notch in the car. every tube fit perfect on the first cut.
    LINCOLN IDEALARC 250 TIG
    LINCOLN SP100 MIG
    15 TON X 4' VERSON PRESS
    VINTAGE W.F AND JOHN BARNES 15" DRILL PRESS
    WILTON C-2 BENCH VISE
    HF 20 TON SHOP PRESS
    TONS OF OTHER TOOLS
    1956 FORD F-100
    1986 OLDS CUTLASS
    1969 PLYMOUTH ROADRUNNER
    1993 DODGE DAKOTA
    1994 DODGE DAKOTA
    1998 FORD MUSTANG GT CONV.
    2003 DODGE NEON
    Mar 2007
    Deltaville, VA
    2,241
    6pak,
    Hope you didn't sprain your shoulder too badly, PATTING YOURSELF ON THE BACK.
    That really helped the OP I'm sure.
    Syncrowave 250 DX Tigrunner
    Dynasty 200 DX
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
    Sep 2009
    southeast mich.
    28
    i'm not trying to pat myself on the back. I'm just tryig to say that if i can do it, anyone can.
    LINCOLN SP100 MIG
    TONS OF OTHER TOOLS
    1956 FORD F-100
    1986 OLDS CUTLASS
    1993 DODGE DAKOTA
    1994 DODGE DAKOTA
    2003 DODGE NEON
    Jan 2010
    Calgary, Alberta
    197
    Here is a link to a program!
    http://www.cobratorch.net/ttn_dxf
    Mar 2009
    Red Deer, Alberta
    18
    I use these http://www.vansantent.com/pipeMaster.htm with ,
    I made a set of "jigs" one end has the tubing size I'm fabing about 8" long with the pipe master on it, then I have a second pieace of tubing " I have various lenth's" smaller so it will slide in side the first piece then U can put it in the gap, slide it apart, get your fit with the "pipe master" take it out trasfer it on to you work pieace then do the other end. it works for me. Not perfect and takes a little time but I find its easier than the programs, for the amount of tubing U will waste trying different bends,notches IMO its faster to try it, and it does not fit save it for another project and build another pieace than it is to mess around with a computer.
Tags for this Thread
