    Phoenix
    13
    Default pipe beveling options
    I am familiar with some of the standard for beveling tools are H&M, sawyer, dearman machines and such. Those use oxy/act primarily, does anyone use a plasma cutter w/ a machine torch for beveling?
    Nov 2007
    Saskatoon, Sask, Canada
    1,270
    Possibly in a shop application but very doubtful that they would use it in the field.
    I'm sure it wouldn't be too hard to buy a machine torch and make the necessary adapter, if the machine torch doesn't fit in the current adapter.
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    2,949
    Default Plasma Beveling
    I'm pretty sure Mathey-Dearman makes a plasma torch holder (straight torch) for their Mini and Maxi chain machines. I'll have to dig out my catalogue.
    Dave
    "Bonne journe'e mes amis"
    KANSAS
    511
    Default Stainless?
    Stainless ???
    Do you need the plasma or just want to use it?
    Mirage machines offers what most call a ''Tri-tool'' It runs on air and cold cuts and bevels up to 4'' thick pipe. Basicly a cross breed between a mill hog and a standard O/A beveling machine. Any company/contractor that does hot tapping services or bolt torqueing should have one.
    http://www.miragemachines.com/Pipecutting.htm
    '08 F-350
    Vantage 400
    SA-250
    SA-200
    Invertec V350Pro
    Invertec V205T-AC/DC
    Miller 12VS suitcase
    Miller spectrum 2050
    Pipe beveler's
    Track torch
    Phoenix
    13
    It's not a need, but I have a PM600 and a good compressor; I wanted to keep my options open and see if anyone had done it, it's prudent to know more than one method of how to accomplish the task. There was a post a while back in one of the welding rig threads and someone with the airpack on wheels that was stored in the trailer mentioned something about using plasma to bevel pipe; that's what prompted the question.
    I'll look at the mirage link, sounds to be interesting.
    Dec 2008
    Arizona
    812
    I'm pretty sure H&M offers the option of using plasma.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Nov 2007
    1,270
    Quote Originally Posted by Rig Hand View Post
    Stainless ???
    Good point about the stainless, plasma beveling would be the hot ticket in that instance.
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
    Feb 2004
    Boulder, Colorado
    483
    If you bevel with air - plasma you will need to do extensive clean up before you weld. I would stick to Oxy Fuel if you cant afford pipe machining equipment. Try these guys, they have some good videos:
    Wachs
    Georg Fischer
    TriTool
    If you want to pursue plasma beveling on steel pipe, you should use oxygen plasma.
    Any stainless pipe work should be machine prepped, not plasma prepped.
    Jan 2009
    29
    Quote Originally Posted by Choctaw View Post
    I have a sawyer with a plasma machine torch it works great. It is a thermal dynamics if that helps
    Trailblazer 302 Airpak
    Dynasty 200 DX
    Dialarc 250
    MM140
    Old Thunderbolt
    Cutmaster 52 "Camo"
    Machine Torch
    JD2 Tube Notcher
    Makita Cold Cut saws
    Sawyer pipe beveler
    Sumner Stands
    Sumner Ultra Fit Clamps
    Next? CNC Plasma Table
