Results 1 to 10 of 17
Thread: welding lens #
    Jul 2009
    Demorest,GA
    12
    Default welding lens #
    What is the lens darkness number yall use for mig welding. I am using a flux cored btw. and what about stick welding. thanks.
    southern California
    1,783
    I mostly use the auto hoods these days and vary the shade from 10-13, depending on light conditions and process/current. When I do wire and stick with my fixed shade hood, shade 11 works good for outdoors and shade 10 works good for indoors. I've used shade 12 with wire and it can be a little dark sometimes indoors or in low light areas but outdoors in the sunlight it works fine.
    Millermatic175
    MillermaticPassport/Q300
    HTP MIG200
    PowCon 300SM, MK Cobramatic
    DialarcHF, Radiator-1
    Hypertherm PowerMax 380
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -LoadNGo utility bed
    -Bobcat 250NT
    -PassportPlus/Q300
    -XMT304/Optima/Spoolmatic15A
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    Augusta, GA
    274
    I use a Miller Elite. It has adjustable shades from 8-13. For stick welding, I set it at 10.5 or 11. But I go by what is comfortable with my eyes. If it seems too bright I'll turn it up some. If it's too dark, then I lower it.. It's all about what you are comfortable with looking at.
    Jul 2009
    Demorest,GA
    12
    I have a cheaper 7-13 auto darkening. but I was just thinking that if it is a low # it could hurt ur eyes. Like using a 7 setting or something but i read on lincoln electric.com that it doesn't matter about the # that is just the shade and that the lens should still keep out light. IDK if that is correct.
    Jul 2009
    Demorest,GA
    12
    OH and i also heard that u want to set it where u can still c ur weld puddle clearly and i went to North Georgia tech for a field trip and went to the welding class and thats the way they had there helmets fixed. JW if this is correct. thanks
    West Valley City, Ut
    69
    I only use two different shades #9 for tig and #10 for mig or stick. I have never had the need for anything darker. No auto-darkening crap hoods. they never have enough neck coverage anyways. I use and love my large view lincoln electric hood i bought from home depot. If you plan on using a good hood(again not an auto-darkening), never use the crappy plastic shade it comes with, everything looks way to orange IMHO(especially the gold ones). Find a glass one like a radnor(brand i use). it's like welding in HD compared to a plastic lens.
    southern California
    1,783
    Quote Originally Posted by Jeep80CJ7 View Post
    I have to laugh a little here.
    That Lincoln hood you bought at Home Depot is made by Jackson and is an HSL100, which is the same hood that Jackson uses in their EQC line of auto dark hoods, as well as their fixed shade hoods. That wide view HSL100 is also available with a 2x4 lens opening in the same shell shape/size. I have several Jackson hoods here, some auto dark, some fixed shade. All provide the same degree of neck/face coverage regardless of the lens type. Jackson sells their hoods to several other companies who also put their own names on the hoods. The HTP Striker line of hoods is made by Jackson too.
    Glass filter lenses are not used as the first (outter) lens in an arc welding hood. The clear polycarbonate safety cover lens is there first in line to cover and protect the glass filter lens from spatter pitting, as well as cracking/shattering, which will cause your face to have a an unpleasant day or few if it cuts you in the process. The safety lenses are also cheap to replace often as needed, versus replacing a much more expensive glass filter lens every few days when it becomes too pitted to see through anymore.
    Try that #10 shade on bright day outdoors for a day of heavy fluxcore or spray arc welding and tell me how your eyes feel at the end of the day and the next morning. Your local Airgas dealer will be happy to sell you a darker shade 4x5 Radnor filter lens to fit your Jackson Lincoln Home Depot hood.
    www.jacksonsafety.com
    www.htpweld.com
    Millermatic175
    HTP MIG200
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -Bobcat 250NT
    -PassportPlus/Q300
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    southern California
    1,783
    Quote Originally Posted by chase1994 View Post
    The lenses are typically supposed to keep out rays from certain harmful sections of the light spectrum. I have forgotten the names of them as it's been a number of years since I was in science class. However, if the shade is too light, the brightness will tire your eyes and make them more sensitive to bright light for a period of time after. My eyes hurt and tear for awhile when I use too light a shade for too long. I use the darkest shade I can still see the weld with.
    Millermatic175
    HTP MIG200
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -Bobcat 250NT
    -PassportPlus/Q300
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    69
    Quote Originally Posted by Desertrider33 View Post
    www.htpweld.com
    cool. you know alot about hoods. that's just awesome.
    so anyways, he asked what we are using. From what I know that's what i use. me knowing anymore about the model or brand of hood makes me in no way a better welder. So i could care less to learn.
    my hood costed me 30 bucks. 8 dollars for a #10 shade and same for the #9. alot cheaper than buying a worthless auto-darkening that makes you in no way a better welder.
    southern California
    1,783
    I don't know how that came off, but I didn't mean any offense to you. Welcome to the forum.
    Millermatic175
    HTP MIG200
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -Bobcat 250NT
    -PassportPlus/Q300
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
Tags for this Thread
