Results 1 to 7 of 7
    May 2009
    Friendswood,TX
    9
    Default Help for a novice
    OK so everyone warned me about not over heating my projects. But like the newbie I am, i over estimated what that entailed. I have over heated the roof of my '56 Studebaker Pickup. I think it's called coffee canning or soda canning? Now my roof is pretty deformed and when I try to straighten it in one spot, The other spot moved. What can I do?
    Aug 2006
    Raymore Missouri
    1,906
    I saw a video on you tube once about shrinking metal. Heat small areas with a torch and then cool with water. This will shrink the metal. Go easy and don't rush...
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Salem ,Ohio
    3,650
    Cool
    You need to shrink it back into place. The best way is with more heat than cool it quick with wet towels. There are lots of tricks to do it with a shrinking hammer and a dolly too. The best way i have seen is how the guys over at the metalworkers site do it. Is take an old SS fry pan lid and put it on a buffer and go over the area to heat it up then cool it quick with the towels. You must use a buffer for low speeds not a 20,000 rpm grinder that will make a missle. You may be able to turn an abrasive disc around backwards and run the paper side to make heat with a disc grinder you will have to try it. I will dig up some info...Bob
    Dec 2005
    wisconsin
    830
    The term is oil-canning. Yes you need to do some shrinking in the RIGHT areas, and the RIGHT way. The torch/water idea, well shrinking, also makes that spot hard, causes stress, and almost impossible to work out, so I would avoid it at all costs. Using heat, some sand bags, and a spoon you can work out oil cans pretty quickly. Visit www.tinmantech.com for some learning material and tools if you dont have them. Oh and I wouldnt bother with a "shrinking disk" either, that works on the same principal as the torch/water. Been there, tried it, tossed it.
    -Aaron
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Miller Spot Welder
    Motor-Guard stud welder
    May 2009
    Friendswood,TX
    9
    Thanks Guys, I thought I was completely screwed.
    Texas
    279
    Trip over to San Jac So. to the autobody class shop, ask for David Brasden(sic) or Jake Staul, the chief instructor and his assistant, they can give ya some pointers to eliminate the oil can effect.
    Good luck
    L*S
    Nov 2006
    346
    SyncrowaveŽ 200
    Lincoln AC/DC 225/125
    Lincoln Weld Pak 100 wire feed
