Results 1 to 2 of 2
    Aug 2009
    9
    Default How do I build a Flange roller?
    'Flange roller' 'Flange turner' 'Fab wheel'
    Whatever term you use Im referring to the device pipe welders clamp in their vice to roll spool pieces. I have scoured the net trying to find information on how to build one to no avail.
    I know how to build the part that the pipe flange mates up to but I dont know how the bearing part is made, or what type of bearing to use.
    If anyone could give me some hints on this it would be hugely appreciated.
    Cave Creek Az
    1,084
    I just use a set of rollers on top of a pipe jack (2 sets). If you want to make one to bolt a flange to you could make one out of a couple of pillow blocks and a piece of coldd rolled. If you want to go even cheaper than that, build one out of a junk rear end from a truck/car. That will net you two bearings and carriers, and an axle with a flange on the end. You can make your own carbon brush from brushes from an engine drive welder or generator. I have found taking a large diameter piece of welding cable, stripping the end and making a holder to let it ride on the axle is sufficient for me. I have heard of guys injecting a copper anti sieze into the bearings or added conductivity. Your mileage may vary.
