Results 11 to 19 of 19
    Hi yes but the question is.....where do you buy those bolt on spindles because they are not welded on are they?
    Feb 2008
    835
    I can see how it would be a little confusing. We get into this mindset that every axle is a tube with spindles mounted concentrically because we see so many like that.
    Weld spindles onto a square trailer frame and the frame is now, by definition, an axle. Albeit probably not a very stiff one.
    But to answer your question, yeah, northern tool, and several internet trailer parts suppliers. Pretty common.
    Can you post a link because my link was wrong as nocheapgas pointed out the flange on that is for the brakes not a mount.
    Lake of the Ozarks MO
    3,446
    I wonder how well a Torflex style could be adapted to this application?
    You can get them in various configurations. It would need to be stiff enuff to not bottom out.
    Unless it would be better if it was to steer...then never mind.
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
    Austin, TX
    621
    This gives me a great idea for hubs for a motorcycle powered kart project.
    Miller Maxstar 200 DX
    Miller Syncrowave 180 SD
    Hitachi 4.5" grinder
    http://mhayesdesign.com
    Jul 2009
    7
    The hubs on the Uhaul dolly appear similar to the bolt-on hubs for rear axles of front wheel drive cars. They can be purchased at most auto parts stores.
    The GM hubs have lubed for life nonreplaceable bearings. Some older Chrysler products have greaseable and replaceable bearings in their hubs.
    Would these be a good choice?
    http://www.ioffer.com/i/Grand-Prix-B...13018-30879861
    Would you just bolt em up with 4 grade 8 bolts and nuts to the uprights? Is that strong enough?
    Jul 2009
    7
    Those would work. They can also be had at auto salvage yards.
    One thing to keep in mine is to have rims that match the hubs.
    Trailer rims usually have no offset while front wheel drive rims have as much as 3" offset. Using the wrong rims can cause premature bearing failure and/or clearance problems.
Tags for this Thread
