    Nov 2005
    North Central Texas
    22
    Default Wire Welder and Plasma Cutter on Same Cart?
    I've found some items and materials to make a Free mobile cart to hold my wire welder, an Argon gas bottle, and a future plasma cutter....
    My question has to do with putting both of them on the same cart. Do you see any problem with the welder and plasma cutter spaced 4" apart and both facing outward and on the same cart?
    Thanks,
    Bill
    3,936
    Sounds alright to me, but you are the guy pushing them around...Bob
    S.W. Pennsylvania
    2,250
    The one thing to be leary of is that you dont restrict air flow to the machines. As long as no vents are blocked you should be ok.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
    Jan 2006
    Albuquerque, NM
    1,788
    I plan on doing the same thing with a Spectrum 375 and my Hobart EZ125, so I guess I don't see a problem either. Post pictures when you get it done please.
    Regards, George
    Jan 2006
    Kinder, LA
    268
    George,
    That is what I did....
    I was careful to make sure I wasn't blocking any cooling openings/fans etc.
    So far, so good.
    LJ
    MM210 w/3035 Spooler
    Stars & Stripes BWE signed by Andy
    TA185TSW w/Miller Radiator 1
    Miller Spectrum 125C
    Parker Plasma 40
    Jan 2006
    long sault ontario canada
    114
    Default lots of room
    Bill make sure you can protect your wire because the plasma can send the sparks all around and they may pit the wire
    smokin ana grinnin for 20 years
    Owner MARKS MOBILE WELDING
    trailblazer 302
    hobart suitcase mig
    miller 30a al spool gun
    laramy plastic welder
    brocco cutter
    pipe beveler
    all walter hand tools
    Nov 2005
    North Central Texas
    22
    Default How often is the "Side Door" opened on the wire welder?
    Cart is almost completed. I'm using the "hammered" paint. In placing the wire welder on the cart, I can put it to the left side. If I do place it on the left end of the cart where the handle is, I will have to always move the welder to open the side door.
    Are there many times when the door to the wire spool and adjustments has to be opened? Will this be a big problem?
    Thanks,
    Bill
    Default Welder & Plasma Cutter on same cart
    I'm a hobbyist, after I justified my first mig machine (Millermatic 135) - I had to built the cart. Then there was the project that the 135 couldn't do - in came 200DX tig setup, and another cart... The angle grinder works great for most work, but I "really needed" a cutting torch - a Spectrum 375 fit the bill - and another cart? No I built a second story attachment to add to my TIG cart. Works great!
    Steve
    Nov 2005
    North Central Texas
    22
    Default Got a picture?
    Steve,
    Could you post a picture or two of you carts?
    Once the wire is loaded, do you get into your side panel very often?
    Thanks,
    Bill
