Thanks. I talked her out of the vines.
I never priced it. But I don't know that my little 110v welder would get enough heat into solid stock.
Thanks. Yeah, the high edge of the table comes out a couple of inches from the wall up at the top when it's in the 'stowed' position. If I didn't storec the clamps there, it could go flat.
Yeah. I cleaned out the garage and put in the flooring during last year's strike. Good use of a lot of dead time.
It's a low-RPM Milwaukee cold saw. I agree -- I don't like the dust and the smell of abrasive blades.
Results 31 to 40 of 47
09-10-2009, 12:28 PM #31
09-12-2009, 11:09 PM #32
- Dec 2005
- 2
Impressive
I was not as impressed by your project (don't get me wrong, it was great) as I was with your sharing the details from conception to installation, KUDO'S DUDE. Looking at the pictures of your garage it is plain to see that you have experience in man vs materials. Who ever would of thunk of tile in a garage, it seems a natural. Metal fabrication can be a real bear, I have never met a know it all type expert. There are many times that I start a project not even close to having an idea of how I am going to get there from here. I always take notes, and detailed pictures of my projects, I hate repeating mistakes of the past. I always include "What I Would Do Different" notes along with the pictures. Measurement in metal working will always bite you just when you think you have it all figured out. I don't know how many times I have had someone verify my measurements, only to discover my mind was on something else and I was off by 1/4" or 8'. Your project was refreshing, entertaining, and a reminder of my early days in fabrication. Purchase yourself some top quality equipment, buy better then you think you will need. You will find a use for it. Nothing worse then having the ability, talent and inspiration to do a home project and not having the equipment to do it. God Bless, great job.
09-13-2009, 02:47 PM #33
Nice looking fence how long do those blades last on your saw? we have a evoultion, been buying those cryo treated blades from partsmaster but thier not holding up for the 200.00 they cost.
09-13-2009, 03:18 PM #34
- Jul 2009
- Western NC
- 14
Picket fence
Jack,
The fence is fantastic, but the narrative is the most complete and informative one I've read here. I'm a real novice, so I like your planning and ideas on how to accomplish certain tasks, even though you, by your own admission, are not experienced in this sort of thing.
Sorry about the little injury, but the project is enviable.
Nctox
[B]Stickmate LX 235AC/160DC
HH210
09-13-2009, 06:52 PM #35
- Jun 2007
- arizona
- 105
faststeel
do you know about FastSteel? I read where you said you had to grind the weld on all 4 sides on the pickets-you can use FastSteel to cosmetically improve a weld. It's a 2-part epoxy putty that you knead in your hands. Home Depot sells it (in the paint department) for $3+. cat
09-21-2009, 06:36 PM #36
Thanks again, for all the positive responses.
My $40 Freud Diablo blade did the whole fence -- all 300 pickets and the rest -- as well as three welding tables and a lot of other miscellaneous cutting. Most of it's been 16 gauge, so it's not really brutal cutting. But I'm happy with the blade. If I had an evolution saw, I'd get the Freud blades for it.
All right. Today I finished the latches for the two gates and the last piece of painting. It's fastened down. There's a traditional gate on one side and a small camouflaged gate on the other. I got a couple of chairs for the front yard, since I'm a lot lazier than my boy. It was a fun project and now it comes in handy every single day.
(Next up, a swing set.)
Here's a full shot that shows the one section (on the right) that needed to be sloped to match the terrain. I could have stepped the sections, but I thought this would be less noticeable.
And here's the gate. I put a bar on one side that goes into a hole drilled into the walk. A slide-type latch holds the other side shut. I still might add springs to make it automatically return to center. We'll see.
Thanks again to everyone for the suggestions and the encouragement.
10-01-2009, 05:14 PM #37
- Oct 2009
- Rocky Hill, Connecticut
- 1
Question on painting
Jack, can you provide details on how you painted the fence? What type of cleaning, chemical or abrasive? What type of primer and paint (brand) did you use? Did you spray it on or hand brush?
John Chunis
10-09-2009, 08:13 PM #38
Jack, it looks fantastic, great job.
10-11-2009, 11:09 AM #39
Iron fence
I read the narrative, looked at the pics, and have been following up. I'm going to tell you Jack...I don't even like fences, but that made me want one. Great job with everything! Keep it up.
Bobcat 225
Radnor o/a
An assortment of
other tools and toys.
The one DANO!
11-09-2009, 02:45 PM #40
- Jan 2009
- 27
Wow, what a great intro to fence fabrication! I have been looking at building one for a shile, and this definately helped. I am also curious as to how you painted the fence, with what, etc. Also, do you think it would work to spray the fences? I have a paint sprayer, and i thought maybe it would be faster than by hand?
