First off thanks Miller for the tape! A customer brought by a project that may require its use ...WOW six broken crossmembers and about ten feet of worn-out floor.
Mike
Results 1 to 10 of 24
Thread: Aluminum dump
03-12-2006, 12:42 PM #1
Aluminum dump
03-13-2006, 05:34 PM #2
The fruits of eight hours of hard labor. UGLY hu?
Mike
03-13-2006, 06:13 PM #3
- Feb 2006
- springvale me
- 89
hi mike looks just like the night mare i fell into last year except mine had all but one broke and no floor left under the liner took way to long to do
03-13-2006, 06:58 PM #4
This one isn`t going too bad yet , but who knows? The only thing I could do without is the tar under the floor that has to be removed in order to get a satisfactory weld! Asphalt trucks are filthy underneath to say the least.
Mike
03-14-2006, 05:47 PM #5
- Feb 2006
- springvale me
- 89
your right asphalt is bad to work with Ido a lot of dumps that hall asphalt thank god some one invented fire
hope it welds up good for you
03-14-2006, 08:10 PM #6
Thanks Garth. The bright spot to this is that the new floor and crossmembers should weld up pretty well. It`s usually a challange to get origional crossmembers clean enough to weld up .
Mike
03-14-2006, 08:35 PM #7
Originally Posted by Wheels
Yet another reason my truck will never haul that stinky black goo!
Don
'06 Trailblazer 302
'06 12RC feeder
Super S-32P feeder
HH210 & DP3035 spool gun
Esab Multimaster 260
Esab Heliarc 252 AC/DC
03-14-2006, 08:52 PM #8
Black gold Don..black gold.
Mike
03-16-2006, 06:16 AM #9
Eight more hours, one more blister, one less grinder!
The first day is such a drastic change it seems like all kinds of progress is being made, but then comes the slow grunt work with the grinder(may it rest in peace).
Mike
03-16-2006, 05:30 PM #10
Grinders. R.I.P.
Wheels , what brand of grinder are you using
? And is that an Ohio plate on that truck ? Dan
