Results 1 to 10 of 10
    Aug 2009
    3
    Default need some help with a new machine
    i recently purchased a miller 180 w/o autoset and started setting it up, below is my setup and im looking for some assistance im having trouble doing the initial setup i can not get the setting on the welder right for some reason, i figure its something completely stupid or something im overlooking, but any adjustments i make i cant get a good SOLID weld out of it, whether it be real choppy or crackling sounding, ground is good...so forth, when it feel like it needs to be hotter i turn it up or turn it down according to the situation and same with wire speed ...i just cant get anyhting good out. some help or another set of eyes looking at the setup may tell me my stupid fix, big problem is i dont have the owners manual because when i got it i told the wife to file it in with all my important documents and stuff and now she cant find it hahaha, got me worried about my other REAL important stuff haha
    Aug 2009
    3
    Nov 2008
    Kansas City Metro
    387
    This may sound silly, but have you checked to see that the connection between the gun and the machine is seated all the way? If it is not seated on the o-rings properly then you will loose most if not all your gas before it makes it to the weld. UMMMM not real sure why I know this!!! But I do.
    Stickmate LX 235 AC / 160 DC.
    Clarke 180 EN Just in case
    Spectrum 375 X-Treme.
    Milwaukee 14" Chop Saw.
    4 x 6 Horizontal Band Saw.
    Projects and Misc Albums
    Lodi, CA
    1,307
    Is the drive assembly connected to the negative terminal? (inside the door?) Switch the cables going to the + and - terminals.
    Lodi, CA
    1,307
    If you still can't find your owner's manual, look here.
    http://www.millerwelds.com/service/ownersmanuals.php
    Alberta
    60
    Check to see if your drive roll tension is good. Back the tension right off and hold the gun facing the floor, pull the trigger so the rolls start feeding the wire you want enough pressure that when the wire hits the ground it will fold over and continue going. Not hit the floor and the drive wheels just slip on your wire.
    After you have that setup its all about playing with your heat and wirespeed. They may have some starting points on the inside of the side panel cover where you access you roll of wire.
    Good luck.
    Cave Creek Az
    1,055
    Solid wire requires DC+ polarity. You need to change the big wire from the drive rolls to the big "+" sign and swapthe other big wire to the "-" sign. You also need to run co2 or c-25 gas when using solid wire. Turn the wire speed all the way down pull the trigger, you should hear a puff of gas coming from the nozzle.
    Good luck.
    Alberta
    60
    Mig is electrode positive so im guessing the cable from the drive rolls supposed to be hooked to the positive terminal?
    Edit: beat me too it.
    Aug 2009
    3
    awesome guys ill check it out when i get home from work and see what kind of change i get i thought it was the opposite way "-" "+"
    Central Fla.
    311
    You can also download the manual from this site. Look under resources at the top of the page. It'll help you get set up. Good luck and have fun.
