Results 11 to 13 of 13
    Central Fla.
    311
    Almost forgot the spool gun.
    [/QUOTE]
    Tom37 - Let me know how you like the spool gun, please. I'm thinking of getting one myself even though I have a Tig outfit. Would make it quicker to weld some larger pieces.
    Best of luck on the regulator. As I said, I solved my problem by switching regulators. Now all is good and so far, I really like the 211. Only thing that struck me was when I pulled everything out and started setting it up was the "Made in China" stamp on the work clamp. Come on Miller. Charge me a couple of extra bucks and put in a "Made in the USA" clamp.
    Nov 2008
    Kansas City Metro
    387
    The reg is defiantly bad!!! I didn't have a chance to call today, but I did mess with it after work tonight. If I have the low pressure backed all the way out and open the bottle ( per the book ) for a time of 5 to 10 minutes to test for leaks, I find that the low side will rise all the way until the needle hits the stopper.
    Thank You M K Swelding
    Osu, As soon as I get a chance I will post pics of it in use. ( Beads that is )
    I sure hope I dont end up disappointed. I chose the 211 instead of the passport due to the slightly higher duty cycle and the slightly higher amps.
    Dont get me wrong. I DONT think I will be disappointed in the 211 as a machine and what it will do. The passport just has a few more features. I think that I read about several different machines to many times and started letting the specs run together. I know that this is an EXCELLENT machine, lets just see what I can do with it in a few days.
    Sporty, I will surly put a post up as soon as I try the spool gun. Again I just dont know how soon that will be.
    The last few weeks we have had pretty mild temps here and now this week its royal HOT. At my day job I go hard till the work is Done, regardless of the weather. So sometimes when I get home I kick back and and try to soak up a little cool low humidity air.
    Stickmate LX 235 AC / 160 DC.
    Clarke 180 EN Just in case
    Spectrum 375 X-Treme.
    Milwaukee 14" Chop Saw.
    4 x 6 Horizontal Band Saw.
    Projects and Misc Albums
    Central Fla.
    311
    Speaking of hot, at 5:00 this afternoon it was 105 in my shop. Glad I got my welding chores done before noon.
