Results 11 to 20 of 22
    Feb 2006
    3,711
    Cool Fans of DC GTAW on Al
    sundown.
    Hawk,
    Pangea (works for NASA) and BC on the Hobart board are big fans of DC and "lab grade" helium for heavy aluminum weldments.
    I've used DC/straight Helium quite extensively in the past, but for many years now, I've found I can get my work done with AC and the addition of about 25% helium.
    DC welding with Helium definitely has it's place, but when you factor in the cost of the Helium along with the higher flow rates required, your covering gas ends up costing you about 7 times as much as using Argon.
    Sometimes you just got no other options though.
    Yea. I know what you mean. The process has been used for years in obscure (to the public) circles. I was really thinking about the final weldments/product(s). When you use 60-70CFH of UHP+/labgrade He it costs big time! Maybe it's just me, but I love to feel the filler penetrate like it does running .040 ceriated tungsten at 140 amps on 3/4" Al. Also pushing 300+amps AC is hotter than helle (had to add an e for the forum to allow it) to me.
    I am nearly 50 and can't count the bottles of high dollar He, tungsten, and filler rod I smoked up over the years. The final product and selling price was good. Now days I rarely see over 40 amps on a TIG. All I do is weld critical stuff with no tolerance for error. Good to hear your input though.
    PA
    372
    Default DC Tig on aluminum
    Hello Hawk,
    I do a little tig welding and am fair on alum but I do not consider myself an aluminum welder.
    My buddies call me the "Clouseau" of tigging.
    But this thread has me intrigued as I thought DC tigging aluminum was a no-no.
    I do not have access (too cheap!) to helium so I am stuck with argon.
    I would love to try tigging alum on DC but am I doomed if I don't have helium or can I try with your suggestions for settings?
    Here are two 3" cubes I made from 1/8" alum (alloy unknown with 3/32" 4043 wire )
    If I remember correctly, this was done at 85 amps - 150 hz - 75% balance - advanced squarewave on my Dynasty 350 (pre - blue lightning feature.)
    thanks,
    Feb 2006
    3,711
    Default Waste of time...
    Nice work Closeau!
    I tigged a 3x3 stainless cube most of the way, filled it with water and welded it shut. It took a couple of trys adjusting the heat. It's full of water and hopefully won't rust. It's kinda like your picture, but SS and solid.
    Nice work on your welding!
    Actually it is a waste of time without helium. I have never had any luck with plain jane helium. Argon will not work with this procedure. It has to be an Ultra High Purity grade gas which costs too much to play (unless you got it like that). I used to run DC GTAW a lot on 1/2 and thicker -TX alloy because it maxed out my 300DX to run AC and it was too many passes. I like to get it done and move on to something else.
    I really have not given specific settings because it is an expensive process to run. I never messed much with it except on a job to job basis. If you are really interested. look up some of my old posts. I think it is all there. If not, let me know and I can send you some specs via PM or I can post to the forum. Let me know.
  4. #14
    Mar 2007
    Deltaville, VA
    2,239
    Hawk,
    LOL,
    Most of my "heavy aluminum" involves marine engine beds and support brackets.
    Give me my 304, Optima Pulser, and 30A spoolgun and we're ready to rock and roll on the heavy stuff.
    I'm "a bit" older than you, but never found high amp tig welding very enjoyable. In fact, I can't imagine tigging with a Dynasty 700 maxed out.
    Syncrowave 250 DX Tigrunner
    Dynasty 200 DX
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
  5. #15
    Feb 2006
    3,711
    Default Too hot
    SundownIII,
    High amp GTAW is very uncomfortable. I am one of those guys that keep on pushing the torch until the weld is finished or it gets too hot to run it. I miss my XMT Omptima, and 30A. My ex has or had it all. She was supposed to sell everything along with all my Dynastys, Engine drives, etc and subtract it from what I owe the settlement.
    Yea man that is the way to do it if you can get away with wire. So much of what I did over the years was 3/4" through 2" -T6 flat bar bends. The runs were short (2"-6") so the DC Tig was almost perfect for the application. I have never struck an arc with the D700. I hope to soon. I think I can find one to demo soon. I cannot afford one for a while-really don't need it now.
    It is really great to hear from you.
  6. #16
    PA
    372
    Hawk,
    Thanks for the detailed response.
    I now see that DC tigging alum is best left to the pros not a bozo like me.
    Plus even if I got high purity helium and got setup for DC tigging with helium, it woulden't make me weld any better so I'll be better served by spending the money on more blue equipment as budget allows.
    I still have fun tigging so I will continue.
    Clouseau
    PS - Does your dog bite?
    thanks again.
  7. #17
    Mar 2011
    2
    Hi sir Broccoli1. Nice information about the AC TIG. I think I should write it up to my notebook.
  8. #18
    May 2007
    Los Angeles
    140
    sorry to bring up an old thread guys but i just got a new dyn 350 and i can't figure out what the difference between balance control vs differential current adjustment. I understand the technical difference between the two but i dont understand why i would use one over the other. if i raise the balance i will put more EN into the work piece and get better penetration and less cleaning and if i raise the EN amperage i will also get better penetration and less cleaning. so what is the point of differential amperage? why note just leave at 1:1 ratio and make my adjustments with balance?? When would i use differential adjustment instead of balance control?
  9. #19
    Aug 2010
    Los Angeles
    1,179
    Quote Originally Posted by regal2800 View Post
    If you are talking about EN/EP ratio, it is the amperage values of each. I believe it has nothing to do with balance. Balance is the time value of each polarity.
    The way I see it is if balance is 70, and EN is 340 amps, EP is 280 amps, then 70% of the time of the arc is EN at 340amps(melting base), and 30% of the time is EP at 280 amps(melting the electrode/cleaning).
    For me I reduce the EP to prevent tungsten erosion and meltback. I also get a more defined bead. Then I adjust my balance for desired cleaning and wet-in. Less EP works better for me on thicker alum. A more balanced EN/EP I use for thinner alum like soda cans.
    You can store up to 9 different AC programs for different applications. I keep all the values stored in a small spiral notebook.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
  10. #20
    May 2007
    Los Angeles
    140
    Yes, you are correct and i fully understand that. But my question still remains as to why i would do that. If im welding thin material and i want a more EP going into the tungsten why can't i just reduce my balance? Reducing my balance will also give me more EP and put more amperage into my tungsten. Does it make sense what i am saying?
    Does adjust the EP/EN amperage individually do something that adjust the balance WONT accomplish? I guess that is the real question i am trying to figure out.
