Page 8 of 20 FirstFirst ... 34567891011121318 ... LastLast
Results 71 to 80 of 194
  1. #71
    Nov 2009
    4
    Default Dynasty 200 torch
    I am looking for a new air torch for a Dynasty 200 - I have conflicting info about whether the Weldcraft LS1712R is compatible with the Dynasty 200.
    I can't find any specific info on the Weldcraft site so maybe this torch model is discontinued.
    Does anyone have any relevant information as to whether this torch will work or not?
    Thanks in advance.
  2. #72
    Jul 2008
    Houston TX
    240
    Quote Originally Posted by rdenis View Post
    Thanks in advance.
    It should work fine. The LS1712R is a 12ft cable (rubber) and a 17 size torch. Here is a link to a seller....http://www.uswelders.com/product_det...product_id=307
    You want a remote cable with the 14 pin connection, not a 5 pin connector.
    pg
    Dynasty 200 DX_set up on 3 phase
    Coolmate 3
    MM 251 w/ Spoolmatic 30A
    Victor O/A Rig
    Baldor 10 inch Buffer
    Rockwell 12 inch Disc Sander
  3. #73
    Nov 2009
    4
    Thanks PG for the quick reply - awesome website here!
  4. #74
    Dec 2009
    Default Converting a Dynasty 200 to a plasma cutter.
    I'm sure this subject has been approached before, can anyone direct me to the dicussion.
    "is it possible to convert my dynasty 200 to a plasma cutter"? I would like to be able to switch back and forth.
    thanks...
  5. #75
    2,635
    Quote Originally Posted by kaha View Post
    thanks...
    Nope
  6. #76
    Apr 2008
    171
    another link or quote
  7. #77
    2,635
    Quote Originally Posted by BC Iron works View Post
    another link or quote by brock
  8. #78
    Dec 2009
    Groveland, Ma.
    5
    Default Dynasty 300 DX
    Hi, I would like some help in getting my Dynasty 300DX set up to weld 1/8" aluminum. I have had this unit new for about 5 years and finally have been able to set it up to use. Any help will be appreciated. Thanks
  9. #79
    2,635
    Quote Originally Posted by grizzquad View Post
    Hey Grizz,
    Welcome to Miller.
    Here is a Tig handbook you can download.
    http://www.millerwelds.com/resources/TIGhandbook/
    I think Chapter 6 has starting parameters to get you started with the Basics.
  10. #80
    Dec 2009
    Groveland, Ma.
    5
    Hi Broccoli,
    Thank you very much, I will try that and see what happens. There is a lot of good info here.
