Page 6 of 20 FirstFirst 123456789101116 ... LastLast
Results 51 to 60 of 194
  1. #51
    Jul 2008
    Houston TX
    240
    Quote Originally Posted by YukonTIGer View Post
    You are absolutely right. I recieved a very speedy reply from Miller about this, and they said the same thing.
    Don't you hate it when stuff becomes obsolete so quick? I was thinking of selling the Dynasty as i have a new (to me) Syncrowave 250, but i might as well keep it, as i won't get much for the "old style".
    My understanding of the subject goes like this.....
    Sometime around July 2008 the change was made.
    Nothing to designate the change other than before or after a certain serial number you either had the update or you did not.
    You cannot update the earlier version machine.
    I had just bought a new Dynasty off Ebay in July 2009 and read of the change here on the forum.
    The break point serial number was given, so I went to check my serial number.
    Although my machine was a 2009 model, the serial number was a lot earlier than the break point number.{ Like 2007.**
    Long story made short, that prompted me to call Miller and see what was the deal. They had no record of my serial number at all.
    It turns out my Dynasty had been stolen and the serial number on it was for a 2007 Millermatic 350 machine.
    I later discovered my machine is a 2009 model by the labels inside and has all the updates except....... I have no warranty because the serial number is not original.
    Just be happy yours is not a stolen machine. The differences are not that great....... pg
    Dynasty 200 DX_set up on 3 phase
    Coolmate 3
    MM 251 w/ Spoolmatic 30A
    Victor O/A Rig
    Baldor 10 inch Buffer
    Rockwell 12 inch Disc Sander
  2. #52
    I saw your post re. the serial number issue. Thats must have been a sinking feeling when you realized what was happening
    Oh well, for what its worth, nothing ever seems to happen when stuff is on warranty anyways, its always a day or two after the warrant expires
    One thing i do to mitigate erratic starts is i have increased my postflows on both AC and DC, I found it made quite a difference in arcstarts.
    Millermatic 251/30a spoolgun
    Syncrowave 250 c/w pulse module
    All adds up to a great home shop!
  3. #53
    Jul 2008
    East Tennessee
    609
    You'd be surprised what that obsolete machine will bring.
    Bernard 3500ss water-cooler
    Rockwell vertical mill
    Beverly Shear B-3
    Beverly Shear JR
    Home-made English wheel
    Milwaukee Porta-band
    " Sawz-all
    Tennsmith 36" stomp shear
    Fixer upper 1982 Lincoln sa200
  4. #54
    Mar 2009
    Hazelwood Mo USA
    451
    Default Average amps
    I was thinking it would be nice to have some way to monitor average amps when you are dealing with the pulse settings. I know it can be done by doing the math, but for a quick adjustment, some way to monitor it would be very nice.
    I usually change the settings, then strike an arc, full pedal, and watch the amp meter to get the average reading, it would be nice to be able to read the average amps with the helmet down or when making the adjustments...
    I made a few welds using about 2 cps pulse 50 percent 20 percent background, it makes a beautiful weld on the turntable but drives my eyes batty, it makes it look like some of the machine welds I have seen.
    It seems that the pulse rate needs to be 50 cps or so to not bother my eyes.
    I think I have too much free time again maybe??
    mike sr
  5. #55
    I'll also be looking at this thread for any new info.
    2 Miller Dynasty 350's
    Miller Axcess 450
    Miller Syncrowave 350
    Miller XMT 350 CC/CV
    2 Miller XMT 304's
    2 Miller CP250-TS's
    Lincoln Power MIG 300 with
    Cobra Max push-pull gun
    Lincoln WP 250 G9 PRO
  6. #56
    Oct 2008
    taxachussetts
    403
    Quote Originally Posted by vin-man welding View Post
    nice idea, Leefy.
    is there a hiden menu settings on a dynasty SD? like thier is with the DX?
    wail. anyone?
    TB 302
    dynasty 200sd
    spoolmatic 30a/wc24
    suitcase x-treme 12vs
    miller 211
    evolution rage 2
  7. #57
    Vin-man Welding,
    Sorry for the delay in responding to your question. Yes, the Dynasty 200 SD has hidden menus that are the same as the DX model. Everything should be the same between the two models with the exception of the Pulse and Sequence features (which are not included on the SD).
    Please let me know if you have additional questions. Thank you
    Joe Ryan
    Industrial Marketing Specialist - TIG
    Miller Electric Mfg Co
  8. #58
    PA
    287
    Just finished an aluminum sign support for a restaurant.
    It is a V shape with 2 pieces of 3/*" thick alum plate welded to a 6" x 6" x 1/2" square alum tube.
    Settings for my Dynasty 350 are as follows:
    AC frequency - 200 Hz
    Waveform - Advanced square wave
    Amperage 275
    EN - whatever the Dynasty calculated - sorry I didn't think to check until I was done. I can recheck the values.
    EP - whatever the Dynasty calculated
    Balance - 70%
    Tungsten - 1/8" pointed 2% thorium - all I have in 1/8"
    Tig wire - 3/32" 4043 alloy.
    The job went well even though my beads are sloppy.
    I did make sure to clean and clean the metals and this saved me from lots of cussing.
    One effect I noticed was that the arc seemed to be very "forceful" for want of a better term. By this I mean that there was a dimple in the center of my arc puddle and the alum seemed to be repelled from the tungsten at the tip.
    I got a 1/2" thick piece of scrap and just ran a bead with no filler and had the same effect. I even tried pushing the tungsten into the puddle to see if I could get the tungsten to touch the alum but the puddle just parted like Moses and the water.
    Have never seen this effect before but again I haven't done a lot of alum.
    Also tried same settings at 100 and 60 Hz with similar results.
    So is this normal or am I doing something wrong.?
  9. #59
    Mar 2009
    Hazelwood Mo USA
    451
    I have noticed this too on high current settings, I dont have a clue why it does it either, but I dont do much aluminum welding either. I dont seem to have the problem with thinner material.
    mike sr
  10. #60
    Mar 2008
    Anchorage AK
    344
    Are their ways to improve the starts on an old 200DX?
