Page 21 of 23 FirstFirst ... 111617181920212223 LastLast
Results 201 to 210 of 225
  1. #201
    Oct 2012
    yuba city, CA
    60
    Default 350 setup downloads
    Quote Originally Posted by 'Stang View Post
    Dave, Thanks for the advice. I'll try to download an owners manual from Miller. Being a factory, our company just put the new Dynastys on the floor. No one I know of ever saw the owner's manuals. I know enough about aluminum tigging to know when something is wrong-just don't know how to fix it on this machine. As you said, the adjustments are endless!
    ...also download this as mentioned prior--this cheat sheet really helps to remind one--where they want to go!
    'This link: http://www.millerwelds.com/pdf/DynastyQuickRef.pdf
    will help-for very basic reference info.
  2. #202
    Default Dynasty 350 EN/EP settings.
    Thanks Dave. I have the quick reference guide. Got one with my 200DX. I'll go through the 350 owners manual and see what I can figure out. I was trying to take a short cut to save time. The company gets a little tweaked about us playing with the new machines on their time. Lol ! Have to figure things out after work, or before I clock in. But, I'll get there.
  3. #203
    Sep 2009
    Key Largo, FL
    24
    Default I do
    Quote Originally Posted by ArcTech View Post
    Does anyone weld anodized pipe with a Dynasty 200? I have a dynasty 300, but I'm looking for a mobile solution to plug into TB 302. I love my 300, just not sure if the 200 has the guts to bump weld anodized pipe. Seems like the amps would need to be run at max, and the duty cycle limited to 20%.
    The other option is high freq box on trailblazer.
    I would appreciate any input!
    -Mark
    I weld anodized pipe with mine all the time. I
    set at 180 amps, 120 freq, 70 bal
    Push button torch control, settings for 1 1/2" pipe.
    200DX, water cooled.
  4. #204
    Mar 2009
    Hazelwood Mo USA
    462
    Default AC pulse
    On my Dynasty 200dx I have a provision for pulse which I use all the time, I am wonderig if there is anything in the works for a sine wave or AC type of pulse?
    The dc pulse when set low enough to work really well drives my eyes nuts with the instant on off......
    I use the dc pulse at about 50 cycles for the above reason, and I also use the foot pedal in a rhythmic fashion to give me a sort of an AC or sine wave type pulse at about .5 cycles per second, this works really well on 22 gage sheet metal and at the slow rate it doesnt bother my eyes.
    22 gage steel
    approximately 10 amps dc average
    wp9 torch at 8-10 cfh 100% argon
    I have about 350 hours on my machine and never a hiccup except for the gas valve which I re-lubed and it works fine again.
    mike sr
  5. #205
    Sep 2013
    Langhorne,Pa
    17
    Default 350 Memory
    Hi Guys,
    I have been using my 3 week old dynasty(sweet machine)almost every day and have a problem with saving setups in the memory,if i setup the paramerters in say #2 and set the EN/EP for "same" and add all the other settings and then add another program in #3 and set EN/EP for independant and add all other settings and then go back to #2 saved program the EN/EP that was set to "same" is now changed to independent but all other settings remained the same,hope that made sense....is there something i'm supposed to do like a save button or something,i'm sure it is something i'm doing wrong.Any ideas? Thanks for your time,Dean
    Miller Dynasty 350
    Lincoln PT 375
    Miller Trailblazer
    Lagun 10x50 Vertical Mill
    Southbend 9x30 Lathe
    Kwik-Way Valve Grinder
    Victor O/A Set
    Delta 10" Vertical Band Saw
    45 Yrs. worth of hand tools & a couple hammers
    Custom Built Cylinder Head Flow Bench 1400 CFM
  6. #206
    Dec 2013
    426
    Default How do I change wave shape?
    I got my new Dynasty 280DX today. I think it's set on a default program. How do I change wave shape?
  7. #207
    May 2007
    136
    on my 350 you enter the advanced tig settings to adjust wave form by pressing the Amp button and Gas/Dig button together. once in there you can adjust all advanced settings including wave form.
  8. #208
    Dec 2013
    426
    I just read through, The only 280 is mine! When was the 280 DX introduced?
  9. #209
    Nov 2003
    3,584
    Quote Originally Posted by Willie B View Post
    About 6 months ago...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
  10. #210
    Jun 2014
    5
    I've read through this entire thread and it seems to be a good idea to centralize a place where process related info can be gathered on a particular machine. I notice no activity in some time now. This is a really good resource especially for a newbie like me. I documented this by cutting and pasting them into one file. I focused on the post that mentioned specific process and the settings used. Good 200DX quick settings reference resource!!! After experimenting with my 200DX, I have a question:
    1. What is the difference between these two settings:
    1. Amp 60, PPS 300, Peak 50, Background 50
    2. Amp 34, PPS 300, Peak 90, background 50
    if I understand correctly, I realize in #1 peak=30amps, background =15amps, and #2 peak=30amps (give or take .01 or so) background = 15 amps. If the numbers are equal the same amps output will the weld characteric (performance) be the same -- minus the use of a foot pedal? Please let me know and correct me if I'm misunderstanding.
    2nd question -- what usually causes an EWG tungsten to ball up when welding mild steel?
