Spooled wire can be straightened with a vise and a slide hammer. Pull until straight. Takes a few hits to get it right, trim off the clamped ends. Won't work on flux core but fine on solid wire. The idea is to stretch it a tiny amount.
Results 141 to 150 of 194
Thread: Dynasty Processes-Set Up
08-09-2011, 09:04 AM #141
- Jul 2011
- 162
08-09-2011, 10:06 AM #142
08-09-2011, 07:57 PM #143
small filler
I use a 18" piece of 1/16" copper tube straightened out, just feed the filler wire into it, this holds it straight, works for me...............
I dont know where to get the copper tube, I think this came off a control bulb from some instrument.
I use it on .023 filler wire, I need to come up with a small spool to mount on the end of the tube so I can load it and go for awhile as I use quite a bit of the stuff.mike sr
10-17-2011, 01:18 PM #144
- Oct 2011
- 2
10-17-2011, 01:55 PM #145
Yes you can do the spot function with what you have, you will have to read the manual to get it setup, I believe RMT2, then push the amp knob in to set the time for the spot function.
Its been awhile since I used this but it is a useful function.mike sr
10-17-2011, 10:35 PM #146
- Oct 2011
- 2
Rm 2t vs spot
Ok so you thnk I can trigger this function with the regular foot pedal. Cool! Reading in the cryptic manual ( English, plain, would be nice.
) I am confused about doing this with the rmt 2t vs spot functions. Are they both pieces of the same puzzle or is the 2t used to vet the extra starting and stopping ramps while the spot function just makes the square envelope?Thanks!Beez
10-18-2011, 07:44 AM #147
set the machine to dc tig.
set the machine to rmt2t.
set the amps you want.
push the amp knob in and release.
set the spot time.
Both the amps and spot time are set with the same knob.
Depress the foot control when you are ready.
experiment with the settings to get the desired weld.
check the attachments, a couple of the pics are of what I did with it a few months back.
The attachments I am refering to are the paperclip in the main title on this thread.
My manual is in english, however it isnt really clear on a couple of things.
I think this covers how to set it up, have fun...........Last edited by popspipes; 10-18-2011 at 08:20 AM.
mike sr
11-06-2011, 10:58 AM #148
- Nov 2003
- 2,019
LinkBack To: Dynasty 300 Problems...
"Miller Dynasty 300DX problem, video inside"
Regardless of the resolution of this problem.. the info contained in it should be available in the "Dynasty Process Setup" sticky.... this is not the first time a dyn owner has had similar probs and will not be the last.....
Does look a lot like Operator Buttonology probs...... I have been outsmarted by my Dyns more than once myself....(200DX & 350DX) no shame to it... they are complex machines with nested menus and a sometimes less than intuitive inteface....
http://www.millerwelds.com/resources...m-video-inside.
I linked it back so that hopefully sometime in the future a perplexed Dyn owner will find some helpful wisdom in it...
11-13-2011, 01:50 PM #149
11-22-2011, 09:35 PM #150
Lowest DC amps is 3
Can anyone tell me why my Dynasty 200DX (Latest) will only go down to 3 amps. Not a big deal but 1 amp is advertised. Thanks.
wayne lewis
