Page 10 of 23 FirstFirst ... 5678910111213141520 ... LastLast
Results 91 to 100 of 225
  1. #91
    I think the Dynasty 200 DX is a GREAT little machine that make some previously difficult welds a snap to do well.
    The portability is perfect and the option to use different input voltages is very handy.
    I haven't used it with stick electrodes yet but I'm sure it will be very good for that as well.
    "If you build it, they will come!"
  2. #92
    Mar 2009
    Hazelwood Mo USA
    462
    I actually used the spot weld function to repair a kitchen utensil, 200 amps at .5 second and the handle is reattached!
    The problem with it is getting it set up for the thickness and type of material. I think it would be more suitable for a production type situation though.
    mike sr
  3. #93
    Jan 2009
    SW Ohio
    135
    Quote Originally Posted by popspipes View Post
    After you use it a few times you'll get a feel for a workable setting. For tack welding, there's a fair amount of leeway.
  4. #94
    Montana
    65
    I am using a 200DX machine at School (University advanced welding class) I am not able to access the advanced features. I would like to change some parameters.
    I am guessing the machine has a lock out code enabled I doubt anyone knows what the unlock code is . What can I do to get in to the advanced features to try a few adjustments to the parameters? I have a feeling someone set a random code not knowing what they did.I have tried the default reset procedure.
    What are the options?
    Mountain Metal
    Dynasty 200 DX
    Coolmate 1
    Miller Trailblazer 302 W/ Kohler
    Miller Suitcase 12VS Wire feeder
    Weldcraft 26 TIG Torch
    Miller 210
    Spoolmate 3035
    Thermal Dynamics 51 Plasma
    Jet 7x12 L Cooled Band Saw
    Delta Drill Press
    Dewalt Chop
  5. #95
    Mar 2010
    3
    Question Dynasty 350
    Just got new 350... Welding 6005-T5 aluminum. 1/8 ceriated tungsten at 250amps. We are having a problem with the tungsten splitting on the arc starts. I am sure there is a setting wrong or an adjustment.. Anyone out there have a good setting to get started. Thanks a lot.
  6. #96
    2,942
    Quote Originally Posted by JRF View Post
    Maybe this will help
    http://www.millerwelds.com/resources...ad.php?t=13746
  7. #97
    I weld T-5 aluminum at 230 amps on the Dynasty 350's (with 4043 filler), but use 1/8" 2% Thoriated tungsten because it doesn't ball up or spit like Ceriated. Sharpen the point a bit, down to a 1/4 of the tungsten diameter and set the balance at 70%.
    Try that I think you'll like it.
    -Kevin
    2 Miller Dynasty 350's
    Miller Axcess 450
    Miller Syncrowave 350
    Miller XMT 350 CC/CV
    2 Miller XMT 304's
    2 Miller CP250-TS's
    Lincoln Power MIG 300 with
    Cobra Max push-pull gun
    Lincoln WP 250 G9 PRO
  8. #98
    May 2010
    Default 200dx
    Quote Originally Posted by piniongear View Post
    It should work fine. The LS1712R is a 12ft cable (rubber) and a 17 size torch. Here is a link to a seller....http://www.uswelders.com/product_det...product_id=307
    You want a remote cable with the 14 pin connection, not a 5 pin connector.
    pg
    What would happen if you had a 5 pin remote? I have a 200dx and it has 4 hours on it and has had the hf start quit twice it is in for repair and the remote they sold me only has 5 pins. I am looking for help on why this is going on. After reading this post im hoping this could be something.
  9. #99
    Mar 2009
    Hazelwood Mo USA
    462
    My 200dx has a 14 pin connector, but only 5 pins in the connector are used, the rest are not installed in the plug on the remote.
    mike sr
  10. #100
    May 2010
    My foot pedal uses 5 pins but has 14 spots.
