Page 17 of 20 FirstFirst ... 7121314151617181920 LastLast
Results 161 to 170 of 194
  1. #161
    Jan 2012
    5
    So based opon what your say what do you think about this Makita GeneratorMax. Output Current: 12,000W/100ARated Output Current: 9,500W/83.3AVolts AC (60Hz): 120/240Volts DC (AMPS): 12 (8.3)
  2. #162
    Nov 2003
    2,019
    Quote Originally Posted by Aaron954rr View Post
    9,500W/83.3AVolts AC (60Hz): 120/240Volts DC (AMPS): 12 (8.3) ??? confusing...
    am assuming that is a typo on your part.. AND that you forgot to include 240vac continuios wattage withoult voltage drop.... otherwise
    You seem to be in the ballpark... but I would call Miller Tech support and ask them.... It is just too expensive a machine to expirement with.... if they give the go ahead and assure you that the warrantee is in full effect... then I would consider going further... not before....
    Look at the Dynasty as a delicate electronic instrument as far as feeding it... would also call the genset manufacturer and ask them...
    Know I am extra cautious.... but I want no part in blowing up somebodys machine.... call Tech Support..
    The more you know, The better you know, How little you know............................. (Old Estonian Saying)
  3. #163
    Jan 2012
    5
    Yeah my bad on the typo... Thanks for your help and maybe Ill plug it in to the maxstar 350 at work first it's Bechtel's, and save mine
  4. #164
    Nov 2003
    2,019
    sure hope that was a joke... otherwise the ethics stink...
  5. #165
    Jan 2012
    5
    Just a joke bro...guess I should of added lol
  6. #166
    May 2010
    Central CA
    711
    Default Miller Already Has It.
    Quote Originally Posted by Bob Miller View Post
    Andy, If there is not going to be a Dynasty 200 book in the near future, how about a Cheat Sheet/Quick Reference Guide.
    You know something that says what all the buttons do, and how to get into the hidden menu and stuff like that.
    I was thinking of doing something like that and laminate it, so you can store it under the welder.
    But it would be better if you did it.
    Good Luck,
    Bob
    Miller already has a Quick Reference, Part#248988.
    All this time and all I had to do was look.
    Good Luck,
    Bob
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    30A w/ WC-24
    HF-251D-1
    Select Lathe
    Exact Mill
    Spectrum 625 X-TREME
    Cutmaster 152
    Kalamazoo Band Saw
    SX60 Arc Station
    FX30 Arc Station
    8-Grinders
    5-Victor O/A
    4- Chop Saws
    2-Drill Presses
    Lincoln SA-200 Blue Tint Red Face
    Lincoln SA-200 Red Face
  7. #167
    Jul 2011
    162
    The output waveforms of conventional generators are pure sine wave. Inverter generators might be different in waveform. Not a good idea to run an inverter welder off an inverter power supply since power factor rating on the welder is based on pure sine.
    Most generators sold in stores are 2-pole rotors and run at 3600 RPM. But most important is the excitation of the rotor is through brushes and slip rings. If the slip rings arc, this can make an output spike. Rotor current is regulated for control of output and is proportional to output current so they are most likely to arc under higher loads. If driving a motor or resistance load, damage isn't likely. Inverter welders? Don't chance it.
    Better generators run 4-pole rotors and run at 1800 RPM. Even better are those which use brushless excitation. That is the kind I have experience with running my 200DX. Mine is a military surplus MEP-002A, rated for 5 kW but capable of 9 kW before frequency drops as it has a 70 cubic inch Onan diesel. 52 amps at 120 VAC, 26 amps 240 and 17.3 amps in 208 3-phase. Since the Dynasty can use it, I run in that mode.
    I've run it at 200 amps SMAW with no problems. Yes, it responds to the load (around 8 kVA) without more than 0.50 Hz variation (unloaded, 60.5, loaded 60). During my last project, it consumed less than two gallons in 6 hours.
  8. #168
    Feb 2012
    3
    Default Dynasty 200 DX hidden menu
    My first post here. I bought my Dynasty 200 DX Mar, '11 and until very recently have not used it except for a short TIG weld to verify that it worked at all. I'm now needing to use the machine for some stick welding. I'm trying to access the "hidden menu" to change the "low" OCV setting to "high" OCV setting. Thus far I have not been able to open the hidden menu at all.
    I'm following directions (I think) in the written owners manual that came with the machine. Obviously I'm doing something wrong as the menu remains hidden. Great name for it by the way............
    Any suggestions? It's probably worth mentioning that I'm very "old school" so most anything made after transformers and tubes is rather challenging to me! Heck, anything that involves the flow of electrons is a challenge!!
    I did try a search for "hidden menu" on this forum but it came up with nothing....
    Thanks in advance, Dave
  9. #169
    Feb 2012
    3
    Default Hidden menu?
    Quote Originally Posted by H80N View Post
    I have been lobbying for that book for years.... think we will be waiting.... for a while longer
    But for beginners on these machines there is a setup video that Miller posted on Youtube.... it covers the basics pretty well... and is free....
    http://www.youtube.com/watch?v=I73S7fBStsY
    This is a very helpful video for a Dynasty newbie such as myself. Thanks for giving the link. I'm still trying to find out how to access the (well) hidden menu..
    Thanks again, Dave
  10. #170
    Feb 2012
    3
    Default Part way there now another question
    Thanks to the short (4+ min) Miller Dynasty menu setup video I got the hidden menu mastered. Stick welding with normal OCV is just like welding with my old Miller Syncrowave 300. So what is the reason for the low OCV setting? Less current draw by the machine? And if normal OCV is selected is there any further advantage to using the DIG setting?
