FATFAB,
There are many hidden menus in the 200. Each is excessed by turning the machine off and pressing a series of buttons on the front panel while turning the machine back on. Depending which buttons are pressed and held will bring you to different menu functions.
These are all outlined in the manual.
Let us know if you still get stuck.
Andy
Results 11 to 20 of 194
Thread: Dynasty Processes-Set Up
08-06-2009, 02:40 PM #11
08-06-2009, 03:05 PM #12
- Nov 2003
- 2,019
Here
Seems like the right thread to address this right here....
thanks
Heiti
08-07-2009, 05:36 AM #13
- Apr 2009
- Webster WI
- 202
Since I'm new to the tig process, I look forward to this thread as being a great asset. If the experienced will start putting the settings of the dynasty for the material they are using, I think it will help all of us dynasty users. Look forward to following and if I ever get good enough, I will add my settings for what works. Now, most of what I could add wouldn't help anyone.
08-07-2009, 07:58 AM #14
Dynasty 200 dx - late model
I have been welding steel stampings,.030 parts and experimenting with pulse on them, It is noisy thats for sure, I have noticed that when starting an arc it will bridge the two pieces easier, and the tungsten point lasts much longer.
I am using .040 tungsten for this particular part.
I am setting the machine at 60 amps 50 percent 50 cycles and 20 percent background to weld the .030 stamping to a .0625 coupling and get 100% penetration. (average amps are 36)
I set it for 34 amps 50 perrcent 50 cycles and 20 percent background to weld the .030 stamping to a .030 spigot fitting on the other end of it, 100% penetration. (average amps are 20)
These are fusion welds, no filler, in the event I need it I use .023 mig wire..
As far as aiding the penetration with pulse, I havent noticed any difference over DC only. I have talked to others that say it makes a big difference, but I havent seen it yet, but then I am old and a bit dumb........
I would like to see a provision on the machine to see what your average amps are when setting up the pulse without striking an arc, this would make changing the percentages much easier without doing the math.mike sr
08-08-2009, 05:06 PM #15
- Apr 2009
- Webster WI
- 202
Wondering if one of you computer guys or gals could design a worksheet to be posted here that would have a space by each type of data for entry by us welders. It would simplify what has to be typed by the person providing the information.
Thinking something like
__________________Type of Welder
__________________Type of Material
__________________Specification of Material (length/width/thickness)
Welder setup
__________________Amperage
__________________EN
__________________EP
__________________Balance
__________________Frequency
______Y - N____________Pulser used?
__________________If Yes Peak T
__________________Background
__________________Gas type
__________________CFH
__________________Tungsten Size
__________________Tungsten Type
_______Y - N___________Gas Lens
_____________________Exc.
I tried in microsoft excel but couldn't lock the range so you could go through the answer area only. Not smart enough.
Anyway, maybe someone could put something on this link and we could fill in the data and attach pics to show the outcome.
Dynasty 350 - My New Baby
Millermatic 210 Mig with Spoolmate 3035
Miller Thunderbolt XL 225/150 AC/DC Stick Welder
Miller Specturm 625 Plasma Cutter
Speedglas 9100 auto dark helmet
Jackson auto dark helmet
18.5 CFM Eagle Compressor
Oxy/Act
Horizontal Band Saw
Dewalt 14" Chop Saw
7 1/2 Dewalt Angle Grinder
4 - 4 1/2" Sears Angle Grinders
1 - 4" Makita Angle Grinder
2 - IR Die Grinders
All of which my wife says will be a "he$$ of a garage sale"
08-08-2009, 06:38 PM #16
I have an Excel data sheet that I use for settings on my pipes, it works for me but mine isnt as detailed as what you posted.
I just typed in the headings at the top and the settings below, and the particular weld on the left side columb.
I use open office which is almost the same as Excel.mike sr
08-08-2009, 08:09 PM #17
nice idea, Leefy.
is there a hiden menu settings on a dynasty SD? like thier is with the DX?TB 302
dynasty 200sd
spoolmatic 30a/wc24
suitcase x-treme 12vs
miller 211
evolution rage 2
08-08-2009, 10:53 PM #18
Andy, thanks for making this a sticky.
I've made alot of progress with the help of yourself and the board, but am delighted to see this thread.
Will post some pictures of the work and settings on my 300DX tomorrow for review.Two Dynasty 350's with Wireless pedals
Profax 250 weld positioner
Bridgeport mill
Logan Turret lathe
RMD tubing bender
Enco vertical saw
Baileigh Auto cold saw
IR 80 Gal dual stage compressor
Misc Fab equipment
08-09-2009, 02:17 PM #19
Nice to finally see a thread like this coming directly from Miller. I have extensive experience with the Dynasty 200's (old and new), the D300, and the D350. I currently have a 350DX and a newer 200DX. If I can help in any way please don't hesitate to ask.
Here are some threads I started regarding the 350DX and the new 200DX.
http://www.millerwelds.com/resources...ad.php?t=11672
http://www.millerwelds.com/resources...ad.php?t=15568Dynasty 350DX
Dynasty 200DX TigRunner
MM 350P
MM Passport Plus
Spectrum 375 Extreme
08' Trailblazer 302
08-10-2009, 09:09 PM #20
- Jul 2007
- 241
When looking at the specs for the Dynasty 350,I notice that to get above the 200 amp range you need 3 phase input power.As a hobbyist with no 3 phase in my garage my current dynasty 200DX is about all the amperage I will be able to get with a plug in unit? Mike
