Page 1 of 20 12345611 ... LastLast
Results 1 to 10 of 194
    Thumbs up Dynasty Processes-Set Up
    It has been requested by a few people to have a dedicated INVERTER thread and stick it.
    This will be a thread mainly for Dynasty machines with their multi set up features. Diversions, while Inverters, are pretty basic and don't really belong in this group.
    This thread is for specific questions regarding set up, menu features, processes or general experiences that feature the Dynasty type machines.
    There also have been a lot of requests for a Dynasty book. Even though this is a GREAT idea and has been looked at, our resources at this time are too thin to take on this exhausting task. It's not as easy as jotting down notes on how the Dynasty welds. It has to follow a progression of features and benefits along with weld samples and practical applications examples.
    If and when the economy picks back up and we gain some additional weld engineers, an in depth book on Dynasty functions could be possible.
    Until then, this thread should help gather some data to help our advanced inverter users and be a collective area where our weld engineers can browse, time willing, and participate.
    This is NOT an area for service issues. I'd like to keep this welding related.
    Thanks!
    Andy
    Fallbrook CA
    20
    A super idea; I for one will be looking forward to seeing it. Many thanks
    Harold
    Harold
    Craftsman Colormatic AC
    Victor Journyman Setup
    Syncrowave 180 SD
    MM210 With Spoolgun
    Dynasty 200 DX
    Spectrum 625 Plasma Cutter
    Miller HD Tape Measure
    Jul 2008
    Houston TX
    240
    I will watch this thread on a regular basis too.
    pg
    Dynasty 200 DX_set up on 3 phase
    Coolmate 3
    MM 251 w/ Spoolmatic 30A
    HTP 625 Micro Cut Plasma Cutter
    Victor O/A Rig
    Bridgeport Mill_3 phase (w/ Acu-Rite 4 axis DRO)
    10 inch South Bend Lathe_3 phase
    Baldor Double Cup Tool Grinder_3 phase
    Baldor 10 inch Buffer
    Rockwell 12 inch Disc Sander
    Cyclone 2ft X 3ft Bead Blast Cabinet
    Quincy 325 2stg- Air Compressor_3 phase
    Graymills Built-in Parts Washer
    Rockwell/Delta Planer, HD Shaper, Uni-Saw etc.
    Jul 2009
    16
    Thanks for the good anwers! I have been trying the "soft" square wave, and the following settings
    300 amps EN
    150 amps EP
    80% balance
    (the frequency has varied, depending on the joint configuration).
    Oh, by the way, I am mostly welding on 1/2" aluminum. (Sometimes it is as thick as 1" though.)
    These parameters have been working pretty well. Thanks again!
    -mjc
    Default 1/2 inch Aluminum Settings
    Hey all,
    Like Andy said, we have realized a desire for an advanced TIG welding setup guide for our more complex products like the Dynasty, but unfortunatly his comments about available resources is accurate. I did want to start building this thread with member submitted parameters.
    Here is a link to another thread which explains ballance, independant amplitude adjustments and frequency for welding thick aluminum (1/2 and up) with a Dynasty 350.
    http://www.millerwelds.com/resources...ad.php?t=18362
    I hope this helps.
    Joe Ryan
    Industrial Marketing Specialist - TIG
    Miller Electric Mfg Co
    Here's the link to the AC TIG: balance control vs. differential current adjustment thread.
    http://www.millerwelds.com/resources...ad.php?t=18449
    Andy
    Apr 2009
    Webster WI
    202
    Quote Originally Posted by Miller J. Ryan View Post
    Hey all,
    I hope this helps.
    Joe, your post does not connect to a site.
    Default Link
    Leefy,
    After I posted this yesterday, something the cyber world got messed up. I was working with the site admin. to resolve it. She must have worked it out with Andy, because the link that Andy posted is the one I was trying to link to.
    Sorry about the confusion.
    Joe
    Joe Ryan
    Mar 2008
    Anchorage AK
    344
    I have been searching for "hidden menu" and not found threads for the older Dynasty 200DX (pre blue lightning)?
    Nov 2007
    231
    Quote Originally Posted by FATFAB View Post
    You might want to open this issue in a unique thread as the 'Dynasty Processes-Set Up' thread should just pertain to documenting settings and so forth.
    If you go here:
    http://millerwelds.com/service/ownersmanuals.php
    and enter your serial number, you'll get the correct owner's manual
    if you can't find the one that came with the machine when you purchased it.
    --dseman
