Results 1 to 10 of 17
Thread: smoker ideas
    Jul 2009
    Low Country Georgia
    31
    Talking smoker ideas
    hey, i am trying to build a small smoker out of a 55 drum and a medium propane tank. I was wondering if there was any special things I need to watch out for, or add to the desing? any one build one and have things they wish they could have done to it?
    Default smoker ideas
    Nitto9, make sure what was in the 55 gal drum. Remember, steel has pores in it, just like your skin. If that drum had poison in it, it could make you very sick or very dead... While I was doing instruction at a tech school, I would not let the students use 55 gal drums unless they were brand new.
    Robbie
    May 2008
    OCEANSIDE, CA
    123
    and it goes without saying that you need to make sure there's no fumes to ignite in either of those.
    DYNASTY 200SD
    COOLMATE 1
    MM140AS
    SPOOLMATE 100
    SPECTRUM 625 X-TREME
    SPECTRUM 125C
    Jul 2009
    Low Country Georgia
    31
    appreciate the concerns, the 55 had grain in it and the propane tank was drained then filled with h20 befor being cut in half. i also started a wood fire in both containers and kept it going for about 6 hours to ensure that the heat would not cause a reacaction with anything that may have been put in either. the temp was much higher then it would be at when i will be smoking it. I hope that doing this would elemenate any posible problems??? any one think that, it was not sufficent???
    May 2009
    Gulfport, Florida
    440
    Nitto'
    That fire would be fine for cleaning out the drum and LP tank.
    After I cut an LP tank I set a fire in it to burn away all that smell, then I make a burner out of it.
    Too bad you cant find a air or LP tank instead of using a 55 Gallon drum. You would be better off in the long run. The life span would increase 10 fold.
    Jul 2009
    Low Country Georgia
    31
    yea, i wish i could get another LP tank just dont want to dish out the dough right now.... Hard times man the next one i make will most likley be a 250 LP tank.... i am going to try to put a couple of coats on the 55 with the high heat paint so that may help extend the life for now.
    Nov 2008
    Kansas City Metro
    387
    Nitto,
    I have built 2 smokers from drums, the first was a learning experience while the second I felt turned out very nice. If you like here is a link of my smoker pics.
    http://picasaweb.google.com/keesfrie...eat=directlink
    The one that is green and white is the second one I built. It is somewhat double insulated by using another barrel as a parts donner. It cooks great and holds its heat very well. I will leave it at that, if you have any questions about it, I would be glad to answer. Also in my signature line there is a link to my photo page where there is a rig of slightly larger nature. I think its named new roof on smoker and the other one is new smoker.
    Good luck, and please show us some pics along the way.
    Stickmate LX 235 AC / 160 DC.
    Clarke 180 EN Just in case
    Spectrum 375 X-Treme.
    Milwaukee 14" Chop Saw.
    4 x 6 Horizontal Band Saw.
    Projects and Misc Albums
    Raymore Missouri
    1,910
    Tom37 what area of KC do you live. I was looking at your smokers and the area looked familiar. Would it be Robandee?
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Nov 2008
    Kansas City Metro
    387
    Monte, I live due North of you, right down I-291 about 3 miles south of the Missouri river. I think in the pics I may have pictures in Shawnee, Independence and possible Jefferson county in Kansas.
    Nitto, I know that you said money was on the lean side. I thought I would throw this out there, Ferrel gas in KC is selling old tanks fairly cheep. A buddy at work is picking up a 550 gal this week, and I believe he said he is paying 150 bucks. But the gentleman offered him a 200 gal for 75. I would think propane suppliers all over would have some sort of turn over on tanks, its probably just a matter of being at the right place at the right time.
    Nov 2005
    130
    Default smoker design
    Good stuff here -
    http://www.thesmokering.com/forum/index.php
    Go to 'Cookers' then the first 'sticky' -
    'Pit building ratio calculator'
    I'm building a small smoker right now too.
    Cooking chamber is 12"d x 18".
