One thing I might add when welding thin panels some of your distortion is going to be caused by your weld bead shrinking as it cools.You should hammer and dolly your beads as you connect the dots between your tack welds.This will help stretch the welds and minimize warpage,and remember anytime you cool the weld quickly with compressed air or water it will shrink the metal, let your welds cool slowly.Mike
Results 11 to 20 of 22
08-04-2009, 07:39 AM #11
- Jul 2007
- 241
08-04-2009, 10:23 AM #12
Got it, good point. I didn't fully weld the patch panel in the first quarter, so I can hammer/dolly from this point on while finishing it.
________________
Greg
Miller 210
Diversion 165
08-04-2009, 11:04 AM #13
When you try the cut-off wheel method, keep it 90 deg. to the bead (like you're going to cut with it) and use light pressure so you don't dig into the base metal. Then switch to the "flapper" or sanding disc for a smoother finish.
Dynasty 200 DX runner
Sync 350 LX
XMT 300 w/D74 and roughnecks
Hobart 135
ESAB PowerCut 875 plasma
08-04-2009, 01:07 PM #14
Got it, thanks
________________
Greg
Miller 210
Diversion 165
08-11-2009, 06:28 PM #15
- Mar 2009
- 11
could try using a heat sink if at all possible....worked wonders for any thin stuff I've ever done!!!!
08-16-2009, 11:14 AM #16
Member
- Jun 2009
- Park Ridge, IL
- 41
08-21-2009, 05:43 PM #17
08-21-2009, 07:13 PM #18
Sync 350 LX
Hobart 135
10-25-2009, 09:51 PM #19
- Feb 2007
- West Farmington, OH
- 746
Dull abrasives will create lots of heat while grinding. You can't use a grinding disk until it's worn completely down while doing body work. You have to keep putting fresh disks on or else you'll end up heating the panel up and warping it.
Backstitch or backstep welding will also help to keep panel distortion down. Just imagine if you had to weld a new quarter panel on an Econoline van with an oxy acetelyne torch!! It's been done before.
Hope this helps a bit.Blondie (Owner C & S Automotive)
Miller 340A/BP
Victor O/A torches
Lincoln SP125
Too many other tools to list
03 Ram 1500
78 GS1000
82 GL1100 Interstate
10-28-2009, 05:48 PM #20
- May 2006
- 176
If the hardness of your MIG welds is a factor making grinding them down tedious, try .023 ESAB Easy Grind (available in 11 lb rolls and larger). It makes for softer and more malleable beads.
If you keep your hammer/dolly work confined to just the weld, you can get the surrounding metal to return to it's original shape. When shrinkage occurs, it's just the weld puddle itself getting smaller, not the parent material.
Miller XMT-350 CC/CV
Miller S-22A wirefeeder
Bernard 400A "Q" gun
Miller 30-A Spoolmatic w/WC-24
CK 210 & WP-18 GTAW torches
Hypertherm Powermax 30
O/A Rig, Enco 4x6 bandsaw, etc.
