Results 11 to 20 of 24
    Jul 2007
    241
    One thing I might add when welding thin panels some of your distortion is going to be caused by your weld bead shrinking as it cools.You should hammer and dolly your beads as you connect the dots between your tack welds.This will help stretch the welds and minimize warpage,and remember anytime you cool the weld quickly with compressed air or water it will shrink the metal, let your welds cool slowly.Mike
    Oct 2004
    119
    Got it, good point. I didn't fully weld the patch panel in the first quarter, so I can hammer/dolly from this point on while finishing it.
    ________________
    Greg
    Miller 210
    Diversion 165
    Jan 2009
    Cleveland, TN
    229
    When you try the cut-off wheel method, keep it 90 deg. to the bead (like you're going to cut with it) and use light pressure so you don't dig into the base metal. Then switch to the "flapper" or sanding disc for a smoother finish.
    Dynasty 200 DX runner
    Sync 350 LX
    XMT 300 w/D74 and roughnecks
    Hobart 135
    ESAB PowerCut 875 plasma
  4. #14
    Oct 2004
    119
    Got it, thanks
    ________________
    Greg
    Miller 210
    Diversion 165
  5. #15
    Mar 2009
    11
    could try using a heat sink if at all possible....worked wonders for any thin stuff I've ever done!!!!
  6. #16
    Jun 2009
    Park Ridge, IL
    41
    Quote Originally Posted by QuazI View Post
    That's one of the coolest thing I've ever heard.
    any pics of the type of heat sink?
  7. #17
    Dec 2008
    Arizona
    812
    Quote Originally Posted by KarateBoy View Post
    I use a big hunk of aluminum (2x4x6) and keep it in the freezer.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
  8. #18
    Jan 2009
    Cleveland, TN
    229
    Get about a 8-12" piece of 1" copper pipe from the hardware store, and flatten out about half of it. Then put about a 45 deg. angle on it. You can get fancy with a handle, or just wrap some electrical tape on it. You can make others with different sizes if needed.
    Sync 350 LX
    Hobart 135
  9. #19
    Feb 2007
    West Farmington, OH
    746
    Dull abrasives will create lots of heat while grinding. You can't use a grinding disk until it's worn completely down while doing body work. You have to keep putting fresh disks on or else you'll end up heating the panel up and warping it.
    Backstitch or backstep welding will also help to keep panel distortion down. Just imagine if you had to weld a new quarter panel on an Econoline van with an oxy acetelyne torch!! It's been done before.
    Hope this helps a bit.
    Miller 340A/BP
    Victor O/A torches
    Lincoln SP125
    Too many other tools to list
    03 Ram 1500
    78 GS1000
    82 GL1100 Interstate
  10. #20
    May 2006
    180
    If the hardness of your MIG welds is a factor making grinding them down tedious, try .023 ESAB Easy Grind (available in 11 lb rolls and larger). It makes for softer and more malleable beads.
    If you keep your hammer/dolly work confined to just the weld, you can get the surrounding metal to return to it's original shape. When shrinkage occurs, it's just the weld puddle itself getting smaller, not the parent material.
    Miller XMT-350 CC/CV
    Miller S-22A wirefeeder
    Bernard 400A "Q" gun
    Miller 30-A Spoolmatic w/WC-24
    CK 210 & WP-18 GTAW torches
    Hypertherm Powermax 30
    O/A Rig, Enco 4x6 bandsaw, etc.
