    Central Fla.
    311
    Default Pipe or rod holder
    Somewhere recently I read a post where someone wanted to know how to hold pipe or rod in alignment for welding.
    I do quite a bit of handle lengthening and some pipe welding so here is what I came up with to help.
    Central Fla.
    311
    Default More
    Sorry, got interrupted and didn't get to explain the holder.
    It is made from scrap I had - 1" X 0.125 angle, 2 1/2" X 0.250 C channel, and a couple of edge clamps. The clamps came from HF and were about $1.49 ea on sale.
    The clamps can be moved back and forth along the length of the angle depending on where pressure is needed. The bottom of the C channel is cleaned to insure a good ground.
    Works great and was cheap and simple.
    Apr 2007
    Ventura, California
    102
    Default Great Jig!
    LOVE IT!
    Effective, simple, compact, inexpensive. Great design! Thanks for sharing.
    southeast texas
    47
    Thumbs up
    i second that, fantastic idea that pretty much takes the guess work out of aligning pipe or rods. thanks for sharing.
