Results 1 to 10 of 11
    Oct 2008
    Oregon
    193
    Default Hour meter on air compressor
    220-single phase compressor.
    I would like to install an hour meter on my compressor, to more closely monitor maintenance..
    Which terminals would I connect to?
    or,
    To which terminals would I connect?
    Millermatic 211 AutoSet w/MVP
    Century 110 volt 90/110 MIG-Gone to my son, in Texas
    Victor SuperRange OA
    Milwaukee Cold Cut Saw
    Milwaukee Portable Deep Cut Bandsaw
    Milwaukee Hole Hawg
    Jet Horizontal/Vertical Bandsaw
    Jet MD-18 Mill Drill
    Orbit Drill Press
    12 Ton Floor Press
    2002 E-350 V-10:
    1983 F-150 4.9L 6
    2004 Honda ST1300
    2007 Suzuki LTA400F Quad
    1997 Suzuki DR650
    Mpls, MN
    1,790
    You'll need a 220v hobs meter, or a step down "control" transformer. The only other way is to use a four conductor power cord and have a neutral leg so that you can connect the hot to one side of the hobs and then the other to neutral. Ground never carries current.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    Queensville, Ontario
    19
    I'd install a 120 volt hour meter, and pull power off of one side of the feed to the motor. Just make sure it is installed after the magnetic switch so that it will count actual running hours.
    Miller Syncrowave 180
    Millermatic 251
    Thermal Dynamics 51 Plasma
    Wolfpac 175
    Etc.
    8,351
    Unless its a screw compressor, like a Quincy, I don't really see the point. Service should be done anyways in a time frame of your, or the manufacturers recomendations.
    Oct 2008
    Oregon
    193
    It is a Quincy piston compressor.
    I seldom use it, so would rather use an hour meter, than change oil and filters
    prematurely (and expensively), per manufacturer instructions.
    If I used it daily, it would fit their schedule better.
    Milwaukee Hole Hawg
    Orbit Drill Press
    12 Ton Floor Press
    2002 E-350 V-10:
    1983 F-150 4.9L 6
    2004 Honda ST1300
    1997 Suzuki DR650
    4,503
    I am with the last post, if it is seldom used a change or 2 in its lifetime may be all that is needed. Not worth it, just the opposite for continuous use, a meter may make some sense. I run a lot, could likely use a change after years.
    Mpls, MN
    1,790
    Lack of running would be worse than running it all the time.
    You've got a big metal crank case which is generally going to stay cooler longer than the air coming into your shop as the temp is brought up to comfort levels, or even naturally in the summer - so now you've got condensation inside the pump.
    If you run it often, the pump will heat up and evaporate that water off, or at least splash oil around to help prevent the corrosion from occurring.
    Obviously, the best option is to simply keep the temp high enough so that condensation isn't an issue. Maybe put it on a timer so it automatically runs for 20 mins once a week?
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
    4,503
    I agree with the thought that sitting is an issue but how long you think it takes to put 25 or 50 hrs on a comp in a home shop? In commercial environment there is a tendency to under rate the hrs and things often go neglected. A body shop comes to mind, I got one from a shop like that, tank filthy and water logged, air filter clogged and while the oil wasnt pristine it wasnt all that bad, the meter would have been put to better use tracking the water dump schedule.
    Mpls, MN
    1,790
    I manually drain my water at the end of the day via a ball valve installed on an extension from under the unit.
    You bring up a valid issue though - if the pump is automatically cycling, then it also needs an auto-drain.
    Shop environments are typically horrible places for machinery. The operators often have little stake in whether the equipment lives or dies, so they could care less about draining the water out. Just as long as the moisture doesn't make it out the paint gun, they don't see an issue with a couple gallons rotting in the tank.
    I bought some tool boxes from a guy who's dad had a small 4 bay mechanic shop and their quincy was a 120gal horizontal mounted from the rafters in a 20' tall building. They'd never drained it and he worked for him for 20 years prior to his father retiring. He said the pump was at least 40 years old. I don't think they ever changed the oil either.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
    Feb 2005
    N.E. SD
    1,381
    I would use a 120v meter and run it off one leg, or run it off the control wiring on the magnetic starter. I'm sure it will have a 120v coil.
    Jeff
