I am planning on building a smoker out of 24" pipe that is 1/4" thick and about 48" long. I was wondering what would be the idea size for a fire box. I was thinking about 24"x24" x24". I am also wanting to build a small trailer for the smoker to be on. I was thinking about building it out of 4" c channel for the frame and building a rack on it to put firewood. I thought about flooring it with expanded metal but wombanized flooring would be cheaper. I am not an expert at this by any means, so i have a few questions. I have not bought any material yet so all feedback on different material types to use would be appreciated. The first question i have is about the firebox size, what would be the optimum size, I know that is a probably a question of personal choice but maybe somebody has some input. i am on a somewhat tight budget so any tips to save money would be appreciated. I am planning on stick welding most of it, because that is what i am most comfortable with, but may also mig some. i wanted to build the actual grating out of SS expanded metal with 3/4 inch angle iron around the edges, but SS is too high. Well I have went on long enough, but any input is appreciated.
Results 1 to 10 of 29
Thread: Smoker
09-13-2007, 07:56 AM #1
- Sep 2007
- Nacogdoches Texas
- 25
Smoker
09-13-2007, 09:16 AM #2
- Aug 2007
- I live in Cheraw, South Carolina
- 112
I don't think the size of the firebox is critical. It is more a function of what you will be using for the smoke - size of the wood. I use to smoke a lot of meat on a smoker I bought from Brinkman. It was an upright model and the only complaint I had was that I had to usually put charcoal in it several times to finished what I had cooking because it didn't hold much charcoal. This usually upset the cooking process because I had to open it up to load the charcoal, and then there was the lag time for it to reach a point where it could bring the temperature back up. A firebox off to the side would eliminate this problem.
A fire box mounted on the side that could take a couple of pieces of wood around 6 inches in diameter and some charcoal would probably be ideal. I just bought another Brinkman from Wall mart with a firebox off to the side. I can measure it if you would like. I had (3) 55 gallon drums that had never been filled with anything and planned to make a smoker out of a 2 of them. I thought about it a long time, and then went up to Wall mart and bought the Brinkman. Please don't kick me off the message board for making this decision.
6010
09-13-2007, 09:24 AM #3
- Aug 2007
- 112
PS
On the Brinkman the firebox is mounted on the side, and I have seen a lot of them made this way. But I have also seen some with the firebox mounted underneath and this seems to be a better location for me. Heat rises and I think it would give more even heating. That is just an opinion I have and don't really have anything to base it on rather than a gut feeling.6010
09-13-2007, 10:16 AM #4
- Nov 2006
- Kodiak, Alaska
- 15
Hot or cold smoke?
If the smoke chamber is mounted under the smoker the smoker is a hot smoker and the smoke and heat cook and season the meat. If the smoke chamber is mounted to the side the smoke only seasons the meat and you need to rely on some type of brine solution to cure the meat. So what I am getting at is it depends upon the type of smoking you are looking at doing. I personally have both types and for meat I like to cold smoke for a few hours and then finish cooking either in the oven or on the grill. For fish or jerky I prefer hot smoking.
Just some food for thought.Millermatic 130
Millermatic 251
Miller Thunderbolt
09-13-2007, 02:26 PM #5
4" channel seems a bit overkill for your trailer unless you plan on hauling a lot of weight. I would drop it back to maybe 2-1/2 or 2" angle iron or some light tubing. I would still use the expanded metal , not SS , just steel, 3/4 #9. SS expanded metal is terribly expensive. If you use expanded metal, you may also want to consider some kind of ash pan for underneath the floor to catch any ash that might accidently fall out.
Ken
Hobart Handler 187
Dewalt Chop Saw
4" Air Grinder
Die Grinder
Rigid Drill Press
Kellogg 10hp Air Compressor
2009 FXDC
09-13-2007, 04:50 PM #6
- Sep 2007
- Nacogdoches Texas
- 25
smoker
I was looking at some 4 inch channel today at the shop and thought the same thing, plus i can save some on money. Thank you for the comments, everybody. Does anybody think that $25.00 a foot for 24" pipe is reasonable? I live in east texas, I know prices can vary greatly in different locations.
09-13-2007, 05:18 PM #7
i just got finished adding a firebox to a 24'' x 3' long grill the box is 18'' sch 40 pipe 24'' long i thought at first it was overkill but once i did a little tweeking in the cooking chamber i can hold between 275 and 300 deg. my intake hole was a bit large so i choked it down untill i achieved what i wanted here are some pics hope this helps.
09-13-2007, 05:55 PM #8
- Sep 2007
- Nacogdoches Texas
- 25
The pit looks good, mine is going to be mounted on a trailer but other than being a little bigger it will be similar. I am planning on building the firebox out of plate instead of pipe though. I have to build it for an Ag. Mech design and fab. class. I was going to build a nice welding table, but it will be a few years before i will be able to afford a shop and would not have anywhere to put it. So i am building the pit instead. If i get where i do not use it i can always sell it later. Anyway thanks for the responce
09-13-2007, 06:10 PM #9
plate is great i just coulnt swing the price the pipe was a gift if i were you i would aim for the same diam. box as my pipe strictly for looks though. the tweaking will come after you cure it the first time then you can learn about your stack and damper settings good luck if you need any help let us know
09-17-2007, 07:04 AM #10
- Sep 2007
- Nacogdoches Texas
- 25
Well I got some material to start my pit this weekend. I have deciede to go with a round firebox, simply because i was given an extra piece of 24" pipe. I was wondering how long i should make my baffle from my firebox to my grill. My smoke stack is going to be at the end of the grilling section so it cannot be too long. I guess it is a matter of personal choice. But any pictures or input would be appreciated.
