    147
    Default Weld-in Bung and adapters ... help find
    Often times i need to have a flush mounted threaded bung set into my steel tubing. I usually mig weld a plain steel nut to the back side of a steel washer. As you know, the mig weld takes up room and i have to cut the receiving hole rather large to accommodate the mig weld bead.
    Does anyone know where i can find a weld-in bung that has a small shoulder ?
    In this photo, the weld-in bung is used to receive the leveling foot pad.
    thanks for any help.
    large size
    http://www.flickr.com/photos/weldhou...7611212793707/
    PA
    378
    jimmy_pop,
    Nice table.
    I used flange nuts for my work table leveling feet.
    Cut the hole for the flange with a hole saw and welded it flush with the tubing.
    Saves welding a washer to the nut.
    Stainless flange nuts are also available for outdoor applications.
    147
    Cool. I'll try to find a flange nut with the flat base like the pic you attached. i dont mind having that small lip to weld to.
    thanks!
    Nov 2007
    184
    Now you NEED to buy a lathe! You may have wanted one before ,but
    now you really need one.
    Dave P.
    Mar 2009
    Corona, CA
    214
    Hit up a racing equipment supply shop...some to think about are Longacre and Pegasus auto racing supply.
    They might have what you are looking for. Could also check out Protofab, I think they make weld in bungs.
    EDIT: Did a little searching since I have nothing better to do right now. http://www.longacreracing.com/catalo...=1317&catid=21
    I have a feeling what you need is a touch heavier duty that most auto applications...so this is the only one Im going to post. Pack of (6) 1/2" 20 thread weld bosses.
    Nov 2005
    130
    Sep 2008
    southwestern ohio
    272
    thanks for posting that website, it helped me find something that I was looking for, NPT Bungs.
    This is an automotive discussion forum that has some great infromation
    www.autobodytoolmart.com/shoptalk
    3,975
    I 2nd the lathe. You can turn so many cool parts to use on your weldments...Bob
    147
    someday, i'll get there.
