Results 1 to 2 of 2
    May 2008
    Mpls, MN
    464
    Default DIY TIG cooler parts
    I have 2 McCann carbonators which include a procon pump, 1/3hp 120volt motor and a stainless steel tank (about 1 gallon capacity). I have tested these and the motor and pump works and no leaks from the pump. I am looking to get $125 each plus shipping for these. Shipping should be about $20 through my work.
    I have a third carbonator of the same kind as above that has a leaking pump I am looking to get $75 for this one plus shipping.
    I also have a small 120volt motor and a procon pump from a cappuccino machine, this motor is much smaller then the standard 1/3hp motors that are used on carbonators. I know the motor works, the pump is untested and being sold as is. $45 for this plus shipping ($10-15).
    Pictures
    -Dan
    Owner
    DW Metalworks LLC
    Miller Trailblazer 302
    Miller 8RC Feeder
    Miller Passport Plus
    Miller Dynasty 200 DX W/Coolmate 1
    Hobart Handler 135
    Hypertherm PowerMAX 30
    Smith O/A Torch Set
    Plus more tools then my wife will ever know about....
    May 2008
    Mpls, MN
    464
    Added Pictures
    Owner
    DW Metalworks LLC
    Miller 8RC Feeder
    Hobart Handler 135
    Smith O/A Torch Set
