Results 1 to 10 of 12
    Feb 2006
    North Platte, NE
    101
    Default Hanger for welding bottle
    I was at a neighbors the other day and he had a hanger over his welding bottle. He had bought it at a farm show. When I seen it I could hardly waite to get home and make one. His had about six hooks and the one I made only has four. Anyway I thought it was very clever and thought I would pass it on.
    Jan 2006
    long sault ontario canada
    114
    Default Saftey first
    Make sure you dont overload it could lead to a messy deal!
    smokin ana grinnin for 20 years
    Owner MARKS MOBILE WELDING
    trailblazer 302
    hobart suitcase mig
    miller 30a al spool gun
    laramy plastic welder
    brocco cutter
    pipe beveler
    all walter hand tools
    S.W. Pennsylvania
    2,250
    Neat idea, I cant help wondering what is holding the bottle upright in the picture.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
    Jan 2006
    114
    thats what i was kinda wondering also if the gas is flamable with the whip and ground kinda close
    trailblazer 302
    hobart suitcase mig
    brocco cutter
    pipe beveler
    Feb 2006
    North Platte, NE
    101
    The bottle is safe in the holder of the Miller 210. Guess I should have took a picture futher away.
    100
    Careful you don't strike an arc against that bottle. Seen the pics,it aint pretty!!
    Feb 2006
    Hattiesburg, MS
    16
    Quote Originally Posted by squig
    It looks like a bottle of argon or argon/mix, which is an inert gas and isn't flammable, but you still have to watch out not to puncture the bottle because of high pressure. Looks neat though. What did you use to bend the shapes?
    Tom
    Feb 2006
    North Platte, NE
    101
    Cables are only hung on the hooks after the machine is turned off. The thing was made in a vise and a piece of rail road iron. I welded it together on the floor and on the bench and not on the bottle. Had to hook and unhook the gas to the bottle a couple of times to test the fit. No welding was done on the tank. And again the cables are not hung up until the machine is turned off.
    Jan 2006
    114
    Thats a good thang
    trailblazer 302
    hobart suitcase mig
    brocco cutter
    pipe beveler
    Nov 2005
    108
    Default Torch Bottle Hanger
    I have a hose and torch hanger on my bottles same principal as tool hanger on this board except I use it for my torch and hose .
    Thanks keep the ideas coming
