Results 11 to 20 of 24
    Mar 2009
    Red Deer, Alberta
    19
    Could you not just cut all sides but 1, then heat her up and let it streatch back to normal. By leaving one side tacked to the frame it won't be so likly to buckel/bow.
    May 2006
    180
    Quote Originally Posted by overkill 19 View Post
    The frame below the tabletop is warped the same as the 1/2" plate. So, no matter whether I cut the top free from all of the welds or just a few, I'll have to shim beneath the straightened top before I reattach it to the curved frame. From that perspective, it makes more sense I think to free the plate from all of the welds. Maybe tomorrow. I'll decide what to do about the crown in the plate after I measure it free of the frame.
    FK is right, there are too many welds holding the top on now. I think the excess heat from those beads and the ones holding the frame together is what bent the top in the first place. I'll not make the same mistake when reattaching the top; fewer welds applied with better timing and spacing are better.
    Miller XMT-350 CC/CV
    Miller S-22A wirefeeder
    Bernard 400A "Q" gun
    CK 210 & WP-18 GTAW torches
    Hypertherm Powermax 30
    Dec 2008
    Arizona
    812
    You might have a difficult time with 1/2", but when I made my table (3/8") I attached it to the frame by welding some nuts to the table (on the bottom of course), welded some spacers on the frame and bolted it down. This let me pull the table straight by adjusting the bolts.
    Of course if you had access to a really big mill, you could just grind it flat!
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Sep 2006
    Okotoks Alberta Canada
    919
    Default $50
    you only paid $50 for the table!, cut the warped plate off and add a new top. For me to buy all the HSS castors and plate to build that table it would cost around 2-$300, so dont waste your time with a rosebud, or cutting some of the welds and try bending it back, your wasting your time, just replace the top
    DODGE 1 TON 6.7
    PIPEPRO 304
    TO MANY TOOLS
    JUST WELDING IN CIRCLES
    rig welders are like wheelbarrows hard to push around
    and easily upset
    go flames go
    Lake of the Ozarks MO
    3,593
    Quote Originally Posted by pipeline Dan View Post
    But dude...what would that prove??? It's the principle
    Besides if he wasn't all hung up on the stinkin' galvanize, it would almost come back flat simply by flipping it and welding it back down in the same spots. And if not at least everything would stay on the table
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Jul 2006
    1,508
    It is nice to have a flat welding table, in time they all seem to develop low spots. With welding dogs, clips, brackets, and whatever to them, then grinding them all back off, wallah low spot!
    3,593
    Which is exactly why I find no use for the galvanize...may as well be painted IMO
    A welding table is a tool... not something to worry about keeping the finish nice.
    Miller WC-115-A
    Miller Spectrum 300
    Jun 2009
    greenfield new hampshire
    884
    Default right on
    a table is a tool, so is a big hammer, both of which meet often, i built mine 25 yrs ago out of a 4x5x1.5 plate which was straight when new, not now and never will be, i use it
    Jul 2006
    1,508
    A nice flat surface to work on is very convenient, makes fabing things up fast. But if you cannot work on an uneven surface you’re in big trouble in the fabrication world. The bigger the project, I go from tri-squares, framing squares, 6-inch torpedo levels to 24-inch, and 48-inch carpenter levels, to laser levels, to 98s, to total stations. Batter boards with weighted piano wire. All depends on the tolerances and size of project.
    Forgot to mention: Mercury filled plumb bobs, or at least brass bobs with coffee cans 3/4 filled with oil.
    May 2009
    Gulfport, Florida
    440
    Are the cans also used for storing Titanium chips and grindings so you don't have any fires.? That's what the Wicked One does with His chips.!
