Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Default Cure for butter fingered Airman
    I run a Fuels Laboratory, and letís just say that the caliber of men that collect samples for me lack the hand eye coordination that god gave a Tyrannosaurus Rex. As a result the collection jars we use have been dropping faster than the value of a dollar. Answer...frickin weld something! This was a very simple project but for those of you that have ever had to engineer around incompetence, I thought you might appreciate this.
    Columbia SC
    165
    neat.. why the bolts on the bottom..?
    Jim
    Have to be able to remove the jar.
    3,928
    Quote Originally Posted by CaseyMckinney View Post
    I collect fuel samples in the refinery and we use plastic coated glass bottles that are used with a Texas Sampler. Even if you drop them they don't shatter...Bob
    Working for the Uncle S often means DIY or wait.
    May 2009
    Gulfport, Florida
    440
    Question Can you handle it.
    It does look like if it's droped the jar could still break. But at least there is a big handle. The guestion is has that been droped since the jar cage was fabricated.???
    Bob
    May 2009
    The Colorado Gas Patch
    185
    Default Hmmm
    As I recall from the sticker at the gas pump:
    It is unlawful to put fuel in glass or unapproved containers.. I know it is a DOT violation as well..
    Not to mention a down right safety hazard, do like aametalmaster does and collect it in a plastic coated bottle (AKA "Approved Container) before someone gets hurt..
    Play it safe!
    Steve
    Bobcat 250EFI
    Millermatic 350P
    Hypertherm 1250
    A Bunch of tools
    And a forklift to move the heavy stuff with..
    Looking at CNC Plasmas
    It's Miller Time - Get Back To Work!
    OK maybe I should have given more background. This particular sample is collected under pressure so the trouble comes from the jar shooting out of their hands, thus the handle and cage. As far as someone dropping it after that, the cage is lined with friction tape and has over a 1/4" annular space. This should be able to handle a short drop. The problem, however, was not to survive a fall rather keep the men from dropping the sample in the first place. I regard to the plastic container that would be a no-go. First off we have to be able to visually check for water, so you have to be able to see through the. Consider this a piece of lab glass for the field. Furthermore some of the fuels we deal with would eat through plastic. Lastly DOD regulations require a 1 quart glass jar. No offence to anyone in the DOT.
    Quote Originally Posted by urch55 View Post
    Bob
    Putting it in the field today, I will be sure to let you know.
    Dec 2005
    wisconsin
    836
    Ahhh but if it IS an approved container, and happens to be made of glass.....
    Seriously the "stickers" at the pump are mostly a CYA for numbskulls that probably shouldnt be allowed to handle fuel in the first place. Glass fuel checking containers are the norm at the airfield. Not to mention glass fuel level sights, glass globes on fuel/water seperators etc etc. Love the "cage" , somewhere at home I have a Sinclair fuel inspection glass from the '40's , has a wooden handle strapped to is a a couple "bumper" rings on the top and bottom. Ill have to see if I can dig that up.
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Miller Spot Welder
    Motor-Guard stud welder
