To help my company make ends meet we all had to take a four week vacation without pay.
For two of the weeks I helped my brother to fabricate and install a ½ ton overhead crane in his shop which will be used to help him to move material from his shop floor to his loft. The design involves an electric winch that is attached to a trolley that runs on a 25 foot I-beam. The I-beam is supported in the middle with a cross beam.
Thread: Gantry Crane
06-29-2009, 08:42 PM #1
- May 2008
- Troy, MI
- 273
Gantry Crane
Miller Thunderbolt
Smith Oxyacetylene Torch
Miller Dynasty 200DX
16" DuAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
06-29-2009, 09:30 PM #2
- Feb 2009
- Salt Lake City UT
- 21
Wow Looks Great.
What wall thickness is the center beam.
Hope you can find more work during your vacation.
g6RacerMiller Dynasty 200 DX
Miller Spectrum 375 X-TREME
06-30-2009, 07:37 AM #3
That sure beats carrying materials up the ladder..
Bob
06-30-2009, 09:29 AM #4
- May 2008
- Troy, MI
- 273
06-30-2009, 02:37 PM #5
- Apr 2008
- Rushville IN
- 50
Monorail
Pictures look more like a monrail, instead of a gantry??
06-30-2009, 04:36 PM #6
Yes that is a monorail and not a gantry.
Good looking job.
Hopefully your building was built with a snow load factor to carry the additional weight.
Try not to use the crane in the winter if you have snow on the roof, otherwise you should be ok.
06-30-2009, 05:15 PM #7
- May 2008
- Troy, MI
- 273
Thanks. I was wondering what to call it. Monorail makes more sense.
My brother's shop is located in southern Virginia, just north of Greensburg North Carolina. The building has a generous snow load but rarely has very much snow. As you pointed out, he was planning on not using it if there is snow on the roof. The "I" beam is designed for 1/2 ton but the electric winch that he currently has on it is rated for 1/4 ton instead of 1/2.
Miller Thunderbolt
16" DuAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
06-30-2009, 06:23 PM #8
- May 2008
- Troy, MI
- 273
It’s funny that you should mention ladders to the loft. While at my brother’s place I also welded together a stairway to the loft. He had some 10’ stair tread stock that we cut up into 3’ treads. Attached is a picture of my brother and me next to the stair channel fabrication. I’m the one the right. In the second picture my sister in law is modeling the completed stairway.
Miller Thunderbolt
16" DuAll Saw
15" Drill Press
20 Ton Arbor Press
Bridgeport
06-30-2009, 06:41 PM #9
