Results 11 to 12 of 12
Thread: Another tank
    6
    Subaru's use something similiar to cool down the turbo when the engine stops. Essentially water still flows through the turbo (and a tank like this ) when the engine stops so, the bearings don't coke. In the case of the Subaru, the cooling system has 2 caps, one on the radiator and one on this tank. Both can feed the real expansion tank that's mounted to the side of the radiator.
    Apr 2008
    Bohemia, NY
    47
    exactly this system has two radiator caps as well and both the rad and this tank can feed the overflow tank. But even tho this car is turboed it has nothing to do with it. Thats kind of interesting that they do that to cool the turbo. Cool.
    Thermal Arc GTSW300
    Syncrowave 300
    Handler 125
    Acorn Table
Tags for this Thread
