Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 73
  1. #41
    Jul 2006
    1,508
    Quote Originally Posted by backsix View Post
    If you're patient you can take this home for $119
    I’m not sure it would be worth it at that price!
    My 3/4” middle / upper die came without being drilled and tapped! The center hole is to small for the die to even fit on the shaft! Called Harbor Freights 1-800 #. Oh yeah just try getting someone on the phone who can speak English! I’ll drill and tap it my self. The cheap little Allen head bolts were the first thing to go in the round file. Could not keep them from backing out, used a duplicating punch to mark the shaft drilled the shaft and bought Allen set screws with 6-MM jam nuts. Also could not keep the bolts on the wheel from backing out. Now the wheel is welded to the shaft!
  2. #42
    Lodi, CA
    1,126
  3. #43
    Jul 2006
    1,508
    I should have known better!
  4. #44
    Sep 2008
    9
    I'fe noticed the HF roll bender. I'd be considering it if I hadn't built one a couple of years ago:
    http://bullfire.net/Roll_Bender/WP_Roll_Bender.html
  5. #45
    Lake of the Ozarks MO
    3,446
    Quote Originally Posted by ed_h View Post
    Nice job
    I see what you mean
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
  6. #46
    Mar 2009
    19
    Default Can't tell you anything about the roller, but have some input about HF.
    I decided to buy their cut off saw. I don't have a shop, just weld for my self thought it would be OK. Well, my first big project was railing around my front porch. After a while, I burnt up my cut off saw. I took it back and they gave me another one. It wasn't long before I burnt that one up. When I was packing it up to take back and get a refund this time, I could not find the receipt. I called the store, and they said bring it back, and we can give you a store credit for the price. I thought that was very comendable on their part. Junk power tools for sure, but everything else I have gotten there worked just fine. Shop crane works great, roller seat is great, and the cheap trailer holding my Bobcat 250 is just perfect for what I wanted.
  7. #47
    Default roller
    Looks great ,would you have plans to share ?
    regards,Ed
  8. #48
    Sep 2008
    9
    pennswoodsed--
    Sorry, I don't really have any plans. I kind of sketched it out as I went. You could get pretty close from the pictures by knowing that the rollers are 5-inch diameter. The shafts are 3/4" drill rod, and the bushings are 3/4" x 1" x 2" oilite type. The black spacers are some kind of plastic. They keep the rollers centered.
  9. #49
    anyone ever done round tubing with these? i want to do some .065 round chromolly and was wondering how well it works for this?
  10. #50
    Sep 2006
    Abilene, Texas
    639
    I have not rolled tubing, but my experience on smaller rollers and what I've learned on forums should apply here. I think the key to rolling anything is to feed it in the rollers straight. If not, the material will come out twisted. For tubing, I would want dies that fit the OD of the tubing fairly close. As long as the dies are lined up and can't drift from side to side, it should work good.
    Jim
