Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 73
  1. #51
    Mar 2007
    132
    I've had one of these for a while now. Haven't used it much, but did test it out.
    A guy over on Pirate4x4 is selling 1.75" dies along with a better shaft/screws.
    There are a few cool pics of what people are doing with them over there.
    -James
  2. #52
    Apr 2009
    5
    Default dies on hubs
    Quote Originally Posted by monte55 View Post
    Now you tell us!! On your "value judgement" of this tool I went early to HF today and purchased it with the square die set. Just kidding. Anyone that thinks this this unit could make such small circles has limited knowledge of these tools. I'm just opening mine and setting it up. If the dies are any good at all it should be worth the price.
    Making a roller die is a real task for anyone even with decent equipment.
    Just takes a lathe and a radius cutter. I made hubs and separate dies that bolt to the hub. For additional dies, I just make the die and never mess with the bearing part as that is in the hub.
    In the pic, the bolt holes are not drilled yet, but you can see each roller die has a 5/8" and 7/8" cut for 1/2" and 3/4" tubing on each die. The larger dies I made only fit one tubing size.
    - Reed
    Last edited by Reed; 08-29-2009 at 12:45 PM. Reason: A bit incomplete, took an assembled pic.
  3. #53
    Aug 2006
    Raymore Missouri
    1,906
    Those look very nice. I'll give you $12.72 for the lot. OK?
    Nick
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
  4. #54
    Apr 2009
    5
    Default pricing . . .
    Nick
    That might be a smidgen below my lowest number. :-)
    - Reed
  5. #55
    Aug 2004
    Milan Michigan
    1,418
    I went to harbor freight for a oil can thinking how bad could they screw that up and came across the Roller and thoght Wow what a deal.
    When I measured the Dies I was disapointed to find out that they are not sized for pipe.
  6. #56
    Apr 2009
    5
    Default it's not a "pipe" roller . . .
    Well in this case they did not screw it up. They called it a "Tubing" roller and that is what it is.
    If I get a job that needs large radius "pipe" bends, I might make some dies for it, but I'll expect a workout using it. This design is not a high load kinda' thing either. hummm, it may slip also. Given it has 2" dia. dies, maybe 1 or 1.5" pipe might work. . . .
    Back to Lurking.
    - Reed
  7. #57
    Salem ,Ohio
    3,651
    Cool
    I don't have an HF roller but i do have a larger slip roll. I run 66" long pcs of small sq tubing all the time and i just had to motorize the thing. That thing is a killer with 100-500 parts. Most of my tubing gets run thru 4 or 5 times to keep it from twisting or curving as i need it perfect. So that becomes a 500 pc run. So keep your eyes open for a 60:1 Boston gearbox and an electric motor to keep everything simple. All push button from there...Bob
  8. #58
    Nov 2006
    Lake of the Ozarks MO
    3,446
    Default Oval tube edgeways
    This is something I have needed to be able to do. I am too cheap to spend $2000+, if I can figure out a way to make a $159 tool do the job with some elbow grease and a little cash here and there.
    The main challenge to this was getting out ALL THE FREEKING SLOP!!!!
    As you can see I added shims to the sides of the rollers and even had to add them on the sides of the upper yoke and the outside of the yoke pin. About $15 worth of the little bugars. I would imagine it would have done fine on round tube but oval-edgeways creates a lot of tendency to shift to one side.
    I would never have believed this die set would have done this job. I would have bet MONEY that the sides would have bulged out...they didn't even a little bit as far as the eye can tell. I didn't mike it tho.
    You can see that it does score aluminum some but some of that washes off and all of it will sand, which is fine for powder coating.
    BTW the stand is a DELTA..you can even see the box in the background.
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
  9. #59
    Jul 2006
    1,508
    Did you have trouble with the wheel slipping on the shaft? I couldn’t get the setscrews to hold it in place, so I welded it! I have a flatbar roller in the same price rage that has the wheel and shaft keyed, with two setscrews, would have been nice if these things were keyed also.
  10. #60
    Nov 2006
    3,446
    Default Set screws
    Well truth is I remembered your post about that and so I was very careful to keep retightening all the screws.
    That part of this is a joke. The set screws on the dies work loose as well.
    I was thinking I'll probably do something like drill it and the dies out and step up to a bigger American size.
    As I suspected...you can do very nice work with this machine but you must be very careful.
    If the Delrin I ordered ever gets here I want to play with making some dies.
    Miller WC-115-A
    Miller Spectrum 300
    SPEEDGLAS 9100XX
