Results 1 to 3 of 3
Thread: Bobcat question
    Jun 2008
    NORTHERN CALIFORNIA
    59
    Default Bobcat question
    Does the Bobcat 225 have a gas tank drain? Need to get old gas out.
    don't want to use siphon method if I can help it.
    Glenn
    Uxbridge, Ontario
    19
    I'm pretty sure if you downloaded the manual off this site, it would tell you were it is. If one exists. What I've done in the past when there isn't a drain, is pull the fuel line off just before the filter, remove the fuel cap, and apply a SMALL amount of air pressure to the tank. Just cover the filler hole with a rag and stick a blow gun in beside the rag. The air pressure will push the fuel out the fuel line.
    Miller Syncrowave 180
    Millermatic 251
    Thermal Dynamics 51 Plasma
    Wolfpac 175
    Etc.
    4,248
    Or make siphon suction using hose and air nozzle.
