Results 1 to 8 of 8
    Jun 2009
    7
    Default Flat Spot Weld Nozzle Project
    Okay folks, I'm going to put up a project that I am working on and I hope to get some good feedback. As you can see from my "amazing" diagram attached below that I am attaching a zinc plated steel weld nut (.047 thickness) to 18/0 stainless steel. I will do this using the Millermatic 140 auto and the Miller Flat Spot Weld Nozzle #176237 that's going for about $18 bucks give or take. My question is what kind of wire should I use for this application? Any thoughts, comments, and snide remarks are welcome here.
    Again, thanks for the welcome to the Miller Forum.
    -Benjo
    Salem ,Ohio
    3,949
    Cool
    I would clean the zinc off the weld nut first. I would use just mild steel wire. But thats just me. Why don't you use a SS nut and some SS wire?...Bob
    Jun 2009
    7
    For some reason the company (Stafast) doesn't have ss for the weldnut i'm using. Sure would make it easier though.
    alabama
    750
    Why use that type of nozzle?
    2- XMT's 350 cc/cv
    1- BOBCAT 250
    1- TRAILBLAZER 302
    1- MILLER DVI
    1- PASSPORT PLUS
    1- DYNASTY 200 DX
    1- MAXSTAR 150 STL
    1- HF-251 BOX
    1- S-74d
    1- S-75DXA
    2- 12-RC SUITCASES
    1- 8-VS SUITCASE
    2- 30 A SPOOLGUNS
    Jun 2009
    7
    I managed to track down a ss weldnut on Friday...actually my wife tracked it down online so we're good to go on that now. Now I will be working on the application method as soon as the weldnut samples arrive. As for the nozzle use goes, I picked that so it will concentrate and limit the heat and material so that the discoloration will be minimized on the ss. I want to maintain a clean result as possible since the product will be used by consumers. I will post up some pics later when the product is completed and on the market.
    Thanks!
    -b
    Salem ,Ohio
    3,949
    Cool
    Quote Originally Posted by fabricator View Post
    You kind of lost me there too. I have welded zillions of weld nuts and never used one of those. Without a timer or some thingy on your welder i think you will be better off with a reg nozzle and a helmet...Bob
    Jun 2009
    7
    I'm gonna give it a try both ways (with the nozzle and without it) and compare the results. Hey metalmaster, since you have welded zillions of weldnuts and i have welded zero...what would you recommend for settings (heat and wire speed) for welding ss to weldnuts to 18/0 ss? I have the Millermatic 140 auto. I am also building a jig for the weldnut attachment so I can cruise on through and knock the project out.
    Salem ,Ohio
    3,949
    Cool
    I don't know about the heat on a 140 as i never used one. I worked in a sheetmetal shop and we attached weld nuts and other same looking fasteners on 1/8" ss plate. But i do agree for a jig so you get them in the right place...Bob
