Results 1 to 8 of 8
    Jun 2009
    7
    Default Flat Spot Weld Nozzle Project
    Okay folks, I'm going to put up a project that I am working on and I hope to get some good feedback. As you can see from my "amazing" diagram attached below that I am attaching a zinc plated steel weld nut (.047 thickness) to 18/0 stainless steel. I will do this using the Millermatic 140 auto and the Miller Flat Spot Weld Nozzle #176237 that's going for about $18 bucks give or take. My question is what kind of wire should I use for this application? Any thoughts, comments, and snide remarks are welcome here.
    Again, thanks for the welcome to the Miller Forum.
    -Benjo
    3,654
    I would clean the zinc off the weld nut first. I would use just mild steel wire. But thats just me. Why don't you use a SS nut and some SS wire?...Bob
    Jun 2009
    7
    For some reason the company (Stafast) doesn't have ss for the weldnut i'm using. Sure would make it easier though.
    alabama
    717
    Why use that type of nozzle?
    XMT 350 cc/cv
    XMT 350 vs
    TRAILBLAZER 302
    MILLER DVI
    PASSPORT PLUS
    DYNASTY 200 DX
    MAXSTAR 150 STL
    HOBART CHAMP
    HF-251 BOX
    12-RC SUITCASES
    12-VS SUITCASE
    Jun 2009
    7
    I managed to track down a ss weldnut on Friday...actually my wife tracked it down online so we're good to go on that now. Now I will be working on the application method as soon as the weldnut samples arrive. As for the nozzle use goes, I picked that so it will concentrate and limit the heat and material so that the discoloration will be minimized on the ss. I want to maintain a clean result as possible since the product will be used by consumers. I will post up some pics later when the product is completed and on the market.
    Thanks!
    -b
    3,654
    Quote Originally Posted by fabricator View Post
    You kind of lost me there too. I have welded zillions of weld nuts and never used one of those. Without a timer or some thingy on your welder i think you will be better off with a reg nozzle and a helmet...Bob
    Jun 2009
    7
    I'm gonna give it a try both ways (with the nozzle and without it) and compare the results. Hey metalmaster, since you have welded zillions of weldnuts and i have welded zero...what would you recommend for settings (heat and wire speed) for welding ss to weldnuts to 18/0 ss? I have the Millermatic 140 auto. I am also building a jig for the weldnut attachment so I can cruise on through and knock the project out.
    3,654
    I don't know about the heat on a 140 as i never used one. I worked in a sheetmetal shop and we attached weld nuts and other same looking fasteners on 1/8" ss plate. But i do agree for a jig so you get them in the right place...Bob
