Results 1 to 3 of 3
    Benton, Pa
    68
    Default Source for cutting edge
    I have a bucket repair ro do on a compact tractor front loader bucket.
    Does anybody have a good source for replacement cutting edges?
    Is it just as easy to go back to John Deere and purchase one.
    1,890
    Aftermarket most likely will be cheaper. Try the phone book for equipment parts or stop by/call any large construction outfit & they would probably know a local guy. I've never had a problem with quality on aftermarket edges, shanks & teeth
    Jun 2009
    So Cal Desert
    25
    Default Replacement blades
    Hi there, Been a lurker far to long!
    Try this! I just purchased a set of replacement blades and bolts for my 1957 Ferguson, Gannon approximately $250.00 + -. They have just about anything you need or they can make it! Oops new rippers also
    www.cuttingedgesupply.com
    Tracy
    Last edited by Ranch Land Toys (RLT); 06-17-2009 at 11:31 PM. Reason: Forgot the rippers
