Results 1 to 8 of 8
    Sep 2006
    Maryville, IL
    75
    Default Motorcycle Paint Stands
    We made some motorcycle paint stands to hold a tank, rear fender and front fender. The stands are generic and can telescope up and down. Then custom mounts were made for each type of part. So when a different type of part needs painting, all we need to do is make a new mount for the part.
    The Generic Stands
    Sep 2006
    Maryville, IL
    75
    The Custom Mounts
    Stands with Parts ready for primer
    Sep 2006
    Maryville, IL
    75
    Default Paint Completed
    Paint Completed with the help of new statnds
    Dec 2008
    Arizona
    801
    Awesome paint job! What technique did you use for the marbling?
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Augusta, GA
    264
    nice job on the paint.. .is that the Alsa Corp. Stuff?
    Syncrowave 200
    Millermatic 211 - Awesome!!!
    May 2008
    OCEANSIDE, CA
    123
    Quote Originally Posted by nocheepgas View Post
    it's usually done with a plastic bag and marbleizer. Nice work BTW, it looks fantastic. House of Kolor has info on their site I believe
    "When using Marblizer, try applying it in layers to create depth. Spray your first layer of Marblizer and use a thin millage plastic such as plastic wrap to achieve a fine tight pattern in your first texture effect. Allow 30 minutes to dry. Apply a second coat of Marblizer, and this time use a thicker plastic such as a painter's drop cloth to create a larger texture pattern allowing you to see the finer pattern underneath. This gives a lot of depth to your paint finish. You could also use different colors of Marblizer for each layer. Be sure to do a test panel before painting you project."
    https://shop.houseofkolor.com/hok/products/shimrin.jsp
    DYNASTY 200SD
    COOLMATE 1
    MM140AS
    SPOOLMATE 100
    SPECTRUM 625 X-TREME
    SPECTRUM 125C
    May 2009
    Gulfport, Florida
    440
    Thumbs up
    Looks like the stands did their job in order for you to do yours. I was thinking what my truck would look like with a paint job like that. Then FLASH I think the paint job would cost more than the truck is worth..
    That is one great paint job.!! If you want to experiment I have a truck for a test subject.
    Sep 2006
    Maryville, IL
    75
    Default Thanks !!
    Yes, the trick with the flames is HOK Marballizer. Then Kandy Cobalt Blue airbrushed on the tips and feathered out. The Red Pin Stripe makes it jump.
    This was the first time using the new stands, the height addjustment feature was great. Paint stands sell for big bucks, so if someone looking to make some bucks on eBay, here is your chance....
    Thanks again,
    Joel
