Results 1 to 10 of 19
    Apr 2008
    254
    Default pipe liners welding 'hood'
    They look like a circular piece of sheet metal with an opening for a set of goggles to be inserted. Thats how it looked in the pics at any rate. I think they were held on the head by the goggle strap. Some also had one side of the circle bent at a right angle to the front (back toward the head). So, why the custom setup? Are they supposed to be cooler or ??? Seemed sort of strange and I wondered about the whys. Any of you pipe line types use this type of hood?
    Sep 2008
    ****son,TN 37055
    34
    Have you ever welded outside and had the sun shine into the backside of your hood?
    I have a "wendy's" brand hood and love it although I'm not a pipeliner. It gets used quite abit, with alot of my work being outside.
    Apr 2008
    254
    No, Im usually inside/under a machine all cramped up groping around for the thing I was going to weld or in the shade in front of the shop. No extensive experience w/ back lighting.
    Looked up the name you gave and that helps...pancake hoods. Hmmmm...they must be cooler too?
    2,949
    Default Pancake Weklding Hoods
    Quote Originally Posted by HayFarmer View Post
    They have a Balsa eyepiece (which you custom form to your forehead & nose) and completely "blacks-out" any background sun. The face of the hood is a pressure formed phenolic face place, and is formed either right or left to protect that side of your face. I added an elk skin liner to my eyepiece to make if more comfortable. They are extremely light weight, and a wide elastic strap keeps it on just right. The flip front model is slightly heavier, but with plastic lenses lessens any fatigue.
    Dave
    "Bonne journe'e mes amis"
    May 2009
    Massachusetts
    42
    I've been curious about them myself..I understand about the goggle design to prevent back flash. My question is the face plate shape..Is there a reason for it being round or is that just the way it is?
    Apr 2008
    254
    Are they durable? Balsa seems a poor fit for the usually rough environment welding occurs in.
    2,949
    Default "Round?"
    Quote Originally Posted by chrisa7164 View Post
    Well, most of us have round faces and heads
    I did send away for some square welding caps, they're out of stock
    Dave
    2,949
    Default "Balsa Salsa"
    Actually, the balsa pieces are a good 1/2" thick, and quite durable.
    Dave
    May 2009
    Massachusetts
    42
    good one..I know a couple guys who could use a square welding cap...I have several fiber metal and an old huntsman helmet..none of them are circular? granted some have a "rounded" shell,but none are a perfect circle like the pancake hood.
    2,949
    Default "Pancakes & Syrup"
    Distinctive trademark design. Some guys wear Nomex hoods underneath, others "doo-rags."
    On small pipe, some just wear the goggles (they make Balsa Goggles too).
    They do, however, keep out the sun!
    Dave
